: Head gasket leak after
brmurph
11-02-05, 12:00 AM
Just finished about 4 or 5 WOT to clean out the carbon, probably do this 3 or 4 times a year (I do more WOT then that just not at one time). Car is now in the shop getting the head gaskets replaced. Car has just under 100,000 miles on it. Not saying the WOT caused the problem but sure seems odd that by the time I got home (two miles later) the car was overheating, just wanted to post the information, will let each of you draw your own conclusion.
BTW cooling system was maintained more often then recommended with dexcool, I will admit that the dealer used tap water instead of distilled water when they changed the coolant, also I believe they flushed it instead of just drain and replace like recommended on this board.
Eldyfig
11-02-05, 01:26 AM
Tap water is not good. You would think a dealer would know better than this. They really don't put the care into your car that you would yourself. And they aren't really as knowlegable as they should be with North*s.
I tend to limit my WOTs to just a couple when needed (when I get the cold carbon rap). Just a couple WOTs and the noise is gone. Never needed 4 or 5. That doesn't mean I baby it though.
I have seemed to notice that 96 and later North*s seem to have more headgasket failures than 95 and earlier. Have you clicked on that link to the left about Dex-Cool Investigation?
auroradude
11-02-05, 07:42 PM
Oh man thats not good. I do a lot of WOT on my 4.0 NS. Not at the same time, but overall I do it 3 or 4 times daily. Usually when passing but lately I have had the speeding urge and tend to go 120 to school and work every morning.
chevelle
11-03-05, 12:26 AM
If the head gaskets starting leaking then they were going to leak regardless of doing a WOT manuever or not. The WOT maneuvers did not "fail" a perfectly good headgasket. If it failed it would have failed anyway. Wot has nothing to do with it.
brmurph
11-03-05, 02:31 AM
If your point is that the gaskets were already weakend and that the WOT pushed "may" have pushed it over the top then I would agree with you. The dealer has the heads off and the good news is that the tops of the pistons are very clean (no carbon) :thumbsup:
Dooman
11-03-05, 09:45 AM
Hmmmmm?
A cousin perhaps?
Pjs
11-03-05, 03:29 PM
I can't help it..Anytime I get on the freeway,(twice a day) it's usually wide open
