: Stays in open loop (?)
tolooka
10-29-05, 11:38 AM
Why would my 97 N* stay in open loop when idling? Scanner says one bank
is lean and indicates a misfire, as high as -24 to -26 fuel trim on one cylinder (not all read the same), at higher rpms it is still lean, but much less, -4 to -8 and an intermitant misfire. I really need help, any ideas? Thanks.
Ranger
10-29-05, 07:33 PM
I am not sure if the FPR will cause this but it is an easy check if you haven't done so already.
mastertech
10-30-05, 02:29 PM
Check your o2 sensor operations....sounds like you have a lazy one.
tolooka
10-31-05, 09:29 AM
Thanks, FPR checked and I put in 2 new Delco O2 sensors, didn't do the trick, so I'm thinking O2 ground circuit, does this make sense?
mcowden
10-31-05, 11:24 AM
How are your plugs and wires? Had the fuel rail recall work done recently? Did the FPR hold a vacuum?
