View Full Version : Code- P0442
samm
10-28-05, 09:57 AM
P0442- Evaporative Emission Control System Leak Detected (small leak)
detrimental to my seville? i wasn't thinking so. however, where is the evaporative emission control system? is that a fancier way of saying the cat converter?
Ranger
10-28-05, 11:22 AM
No, the EVAP system takes gas vapors from the tank, stores them in a charcoal canister when the engine is shut down and burns them when running. It is part of the emission control system (gas vapors in the air, ozone, yada yada yada). The first thing to check is the gas cap. If it is loose or not sealing properly it will trigger a DTC. There is also an EVAP purge valve and control solenoid, probably on the rear cam cover that controls the system. Check all the vacuum hoses and electrical connections.
mcowden
10-28-05, 12:01 PM
Yup, I'm with Ranger... The only thing I would add is that some cars have had minor accidents and cracked the canister. If you can see the whole thing, check the canister itself for structural cracks as well as all the plastic lines going into it. If absolutely everything has been checked and nothing else makes sense, there is a one-way valve on the top of the canister that can go bad. Though it would be a rare occurrence, it could happen. Not sure if just that valve can be replaced or not. It might be a new canister. The car will run just fine with this problem, but your SES light will probably stay on until it's fixed, and you won't pass an emissions inspection if you need one.
samm
10-30-05, 06:25 PM
oh, ok, where is the rear cam cover? not too familiar with the engine layout yet. thanks
Ranger
10-30-05, 08:30 PM
The cam cover is what you used to call the valve cover. The rear one is on the firewall side.
samm
11-17-05, 12:57 AM
well i reset the code and it hasn't showed up again yet, so good news? could have been a loose gas cap i suppose. if i cleared the code that doesn't prevent it from coming up ever again does it?
Ranger
11-17-05, 12:45 PM
Nope. If the fault is detected again, the DTC will reset.
