: Anyone have detailed Tech II instructions
slow35th
10-27-05, 09:10 PM
to enable the Competitive Driving mode on a newly installed Nav. unit? The Tech that installed my new nav unit can't get it done. His software is up to date.
ctsvett
10-27-05, 09:26 PM
here is what I pulled out of a TSB:
To select the vehicle type using the Tech 2 go to the radio under special functions, set options, vehicle type, then select the appropriate vehicle.
...THAT MAYBE ALL YOU NEED
ADDITIONAL INFO (IF necessary)
Then with the Tech 2 go to radio, special functions, set options, optional
modules, then select the appropriate modules to set up (Memory seat module, OnStar, DVD, Tire pressure monitor, DRR) and save options. It is necessary to cycle the ignition off and open the door to disable RAP to save programming.
Reed
ssmith100
10-28-05, 12:02 AM
Lance,
The Conroe dealership or some where else??? They got mine working fine.
Shane
slow35th
10-28-05, 09:46 AM
Lance,
Shane
It will go into competitive driving mode?
