View Full Version : Tuned PCM question
cadnathan
10-24-05, 10:19 PM
I installed the tuned PCM on my escalade and the check engine light is now on. I knew that it would be, but I didn't know how tough it would be to find a shop with a Tech 2 scanner to perform the crankshaft relearn. Anyone know what else I can use besides the Tech 2 to clear the check engine light and do a crankshaft relearn?
Thanks in advance
slk230mb
10-24-05, 10:24 PM
The major tuning software should be able to do it. I.E. EFI Live and LS Edit. Any shop with a Tech 2 can perform the relearn also.
hcvone
10-25-05, 07:46 AM
The company/person that tuned the computer should fix the problem, I had my computer reprogrammed and have not had any error messages, who did the tune?
slk230mb
10-25-05, 10:11 AM
But you had your stock PCM tuned right? He probably swapped in a new PCM with the tune, which doesn't have the values for the crank position.
v10king
10-26-05, 01:27 AM
I have a w4me PCM in my 02 5.3L and the check engine light came on. I brought it to an AAMCO, they had a Snap-ON tool. The guy there couldnt figure it out after we found the program area in the tool. He let me do it, 1 minute later done.
