View Full Version : with the engine now out, what should I replace?
chance_b
10-21-05, 12:54 PM
With the engine dropped out of my car nowand the heads removed, I'm just going over everything I should replace before reinstalling. What do you guys think I should buy? And only what's necessary please, as I gotta keep my costs down as much as possible.
So far, this is what I'm thinking (aside from head gaskets of course)
-intake manifold gaskets
-throttle body o-ring
Well that's a pretty short list so far, so what would you guys recommend? Thanks!
EcSTSatic
10-21-05, 01:02 PM
Power washing the engine compartment is always a good idea. Look for rust spots that can be treated.
How are your suspension bushings?
Any lower oil leaks need fixin'?
How do the O2 sensor(s) look?
chance_b
10-21-05, 02:15 PM
i'll shampoo for sure, and the engine too - i never did before removal and she's really grimy.
suspension bushings look alright for the most part, rubber didn't looked cracked or worn really from what i remember... however there was a slight knock/bump coming from the lower left suspension i believe, which i heard during the short time i had it on the road between buying and putting it on blocks. i've heard it's probably a balljoint, or maybe a tie-rod. not sure about the tie-rod, but i'm going to test for balljoint movement when i set the cradle back in the car.
as for oil leaks, i think i'm fine. after draining and shampooing, i'll fill back up and doublecheck for leaks.
o2 sensors? i'm assuming those are the sensors which thread directly into the exhaust manifolds (excuse my lack of knowledge here)? i haven't taken a good look at these, so what should i be checking for when i give them a visual inspection later on tonight?
what about the exhaust manifolds? should those be replaced?
haha, and btw.. does someone actually make that fuel guage you have as your icon or whatever? thats funny as hell, wouldn't mind buying one
EcSTSatic
10-21-05, 03:01 PM
You can tell how your car is running by the color of the O2 sensor. It should be white. Black is a sign of a rich condition. Some people replace them as a regular maintenance item every few years.
Exhaust manifold should be okay.
Nope, the gauge is just a pic. Sorry :)
chance_b
10-21-05, 04:27 PM
thanks, i'll check the o2 sensors after work then. and as for the guage.. haha ah well. i just picked up an '80 el camino tho for $100 (rusted out floor/body mounts, no engine) so i think i just might try to mod the guage on that thing to match your pic. if i pull it off nice enough i'll post a pic ;)
EcSTSatic
10-21-05, 04:44 PM
I'd like to see that. Maybe there's a market for it. :thumbsup:
zonie77
10-21-05, 08:10 PM
Now would be the time to replace the lower case seal if it's leaking.
davesdeville
10-21-05, 08:51 PM
What about the plastic HVAC cover that cracks all the time?
chevelle
10-21-05, 11:48 PM
Replace the two seals between the oil filter adapter and the block. There is likely a lot of grunge around the oil filter adapter and below it. That would be from the oil filter adapter seals.
To remove the intake manifold from the engine just remove the four inner, recessed bolts in the intake cover. Do not remove the perimeter bolts in the cover, just the four inner, recessed bolts.
When you have the intake off to remove the heads look at the intake manifold spacer plates. They need to be cleaned. The EGR passages in the spacer plates will likely be full of carbon. Don't overlook the small machined notches in the cylinder head itself at each intake port.
If the lower crank case looks dry I would leave it alone, personally.
BodybyFisher
11-02-05, 11:52 AM
chevelle is there any benefit to tightening the lower crankcase bolts if you had a leak? Scotty
