View Full Version : 15000 mile front dif need to change?
drjdan
10-15-05, 08:30 PM
I have a 2004 Escalade AWD with 22000 miles. I took in today for some service and an oil change. The adviser said I need to change the front dif fuild and that is it a normal 15000 service item. But he did bable a little when I ask him if it is really needed saying it sometimes gets dirt in it. I live in Dallas and do local and freeway driving--no off road. I have in on a Smart Buy and will be turning in at 42000 miles.
Does this need to be done?
fast66
10-15-05, 11:29 PM
no clue, whats smart buy?
psykiv
10-16-05, 07:06 AM
whats smart buy?
Fancy term for a lease with an option to buy.
OCESCALADE
10-16-05, 06:06 PM
he is upselling you something you do not need. Look they say not to change the transmission fluid til 100,000 miles or 50,000 if you do a lot of towing. Generally front and rear ends i would, at a minimum change at 50k. Tell the service advisor to get a second job if he needs the money that bad.
JOHNNYRENO
10-16-05, 09:28 PM
I know of some grease that needs changing and it isnt in differentual.
hcvone
10-17-05, 08:30 AM
I change all my fuilds to synthetic oils at the first oil change, they just protect better than standard oils. I change my rear's, transfer case and transmission oils every 25k miles, probably overkill but I do it myself so there is no labor costs. The service manual shows NO changes to the front or rear diff's up to and including 100k miles (that is way too long) and shows the trans fluid change at 100k, you will probably need to replace your trans if you would wait that long.
dnyce617
10-17-05, 11:07 AM
I'm not sure about the reccomended fluid change interval is, but my front diff just needed to be rebuilt at 26,000 miles and I never changed it.
DenverEXT
10-17-05, 03:12 PM
I doubt that was caused from not changing the fluid. Something else went wrong there. That sucks.
