View Full Version : Front Cd Player with Those with only Tape Decks KEEP YOU STOCK RADIO!!!
CadillacSTS2003
10-14-05, 02:59 PM
Want a front mounted cd player so did i so i was just about ready to rip out my bose and redo the entire system. Well that seemed to difficult so i figured out a much simpler way to do things. You need a cassette adapter, an after market cd player and enough wire to run 3 wires from your battery to your glove box. 1st run two wires from the positive terminal on your battery and one from the ground terminal to your glove box. Connect one positive wire to a switch then to the red wire on the aftermarked cd player, the other positive wire directly to the yellow wire and the ground wire to the black wire. Next get an rca adapter that turns red and white rca into a single head phone jack (at radioshack or some place like it). Plug the red and white rcas into the rear output on the aftermarked cd player. Push the cassette adapter in your radio run the wire from there into your glove box. Connect the tape adapter wire to the rca adapter. Turn on the switch you installed turn your stock radio source to tape and there you go!!! Hope this helps everyone whos stuck with a bs tape player
CadillacSTS2003
10-19-05, 02:06 AM
hope this helped someone
JC316
10-19-05, 03:12 AM
Pretty slick design. It saves the headache of rewiring the whole system and finding a dash adapter or the pricey double din stereos. The audio will degrade slightly, but otherwise it is good. Good job!
powerglide
10-21-05, 03:42 PM
Had a similar rig before, it gets the job done. Congrats!
No gain in sound quality though.....
CadillacSTS2003
10-22-05, 12:40 AM
yea but for those with a 96-97 bose system its the only alternative im not about to pay 400 bucks for a custome install or adapters to keep my bose speakers
