wingnutt
10-13-05, 06:11 PM
2001 Seville SLS (Northstar 4.6) will NOT give us the time of day. it made NO noises when turning key. so, started with cheap options first...
cleaned battery cables...no luck
swapped relays around...started once, then no luck
put in new battery...no luck
put in new starter...started once, then no luck
so, after the second start, we noticed the check engine light came on. so, we pulled the codes...
PO335 crank sensor circuit A
PO340 cam sensor A
PO385 crank sensor circuit B
PO601 check sum error
PO507 idle control high
cleared the codes, diconnected the battery for a few hours, replaced the knock sensor (after tearing apart to make sure we didnt forget something from the starter swap) and we are still at square one.
THEN we notice that we have a theft system service light....AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAARRRRRG!!!
...anyone got any ideas???
PO340 cam sensor A
