Hello all,
So driving the other day and started to hear a loud noise coming from the engine bay. I inspected and it appears the clutch assembly has fallen apart. The compressor works but noisy. Has anyone just replaced the clutch assembly or is it better to change whole unit.
If whole unit I know it's recommended to replace the dryer as well. Should I change everything or the comp only. Also I have done comp changes before does not look hard. I just want to make sure I get it installed correctly I dont want to do it again. I have a vac pump but not sure about oils etc.
Any suggestions?
Any suggestions?
