mgj1051
10-11-05, 02:37 PM
I took the battery out of my car to charge it now it wont start plz help it is a 98 catera
| View Full Version : wont start mgj1051 10-11-05, 02:37 PM I took the battery out of my car to charge it now it wont start plz help it is a 98 catera inconnu 10-11-05, 06:18 PM Is the motor turning over ? madcat_ss 10-11-05, 08:04 PM By not having a battery back-up when you disconnected the battery, you might have inadvertently erased vital info that the ECM would use to start and run the car. That's just my guess. You may have to bring it to the dealer. MADCAT bengsxr 10-12-05, 09:14 AM I go with madcat on this one. the dealer will charge about $100 bucks to reprogram your computer to work with the car. you will also have the tow charge on top of the $100. mgj1051 10-13-05, 10:29 AM so what you are telling me you cant take the battery out of car to replace it inconnu 10-13-05, 12:20 PM so what you are telling me you cant take the battery out of car to replace it I have taken out battery few times nothing happened but if you could tell us what happens when you try to turn on the ignition The battery you are using is properly charged if yes i think you have lost a ground connection or something try explaining in details the experts in the forum will be around one time or the other they can help you better if you give more details surfsidetex 10-16-05, 01:51 PM sounds like the key is not recognized,my have to have dealer program key?just a hunch,my key got damaged and chip was missing out of key and it would not start. bengsxr 10-16-05, 04:49 PM ok try this one if the car will crank. turn key to run postion do not start it leave for three minutes then turn key off. then back on and leave running for 30 seconds or more. I got this out of my 99 catera manuel. it says to do this anytime of a power loss to let the electronic throttle control cycle to find its home postion maybe this will help you. oh yeah section 6-29 in my book. | |
