View Full Version : Projector Lamp problem, please help NolaBoy 10-11-05, 09:33 AM I just purchased some projector lamp headlights for my 99 Cat They look great compared to the yellowed stock headlights. Here is my problem. Ok I installed the passenger side headlamp first. installed the bulbs, plugged in the harness and let there be light. beautiful. worked like a charm. Well that was simple enough so now we move on to the driver's side headlamp, installed the bulbs and plug in the harness and turn on the headlights ... well i am getting very low output from the driver's side and also both the hibeam and lowbeam on the passenger side are now lit up :banghead: What on earth is the problem. Am i running into a short somewhere. I know its not rocket science but am i missing something? Its funny cause my friend said oh it shouldnt take that long to change them. I said yeah it shoiuldnt but nothing comes easy on the catera. Any help would be greatly appreciated thanks. NolaBoy 10-11-05, 05:52 PM no they are aftermarket projector headlights from a 98 Opel Omega. i got em shipped from germany. Try switching the bulb that is low to the other side and vice versa. NolaBoy 10-11-05, 06:13 PM nope. standard bulbs. NolaBoy 10-11-05, 06:14 PM Try switching the bulb that is low to the other side and vice versa.
tried that and the results are the same revin24 11-22-05, 05:34 AM try a relay circut to pull power directly from the battery and use the current power wires to trigger the relays. if you do this i suggest useing 40 amp relays the results are quite pleaseing if you do your headlights will not only be brighter but you can use a higher power bulb "now were talkin":D :D :D :D sanchman 11-23-05, 11:47 AM This might sound weird but I had the same problem. I bought mines from Germany as well. I took one of the ground wires from the old headlight, (brown wire), removed the original ground from the new lamp, just off the groove that it is attached to and connected the one from the old lamp to where the ground wire was positioned on the new headlight. Then direcectly connected the other end to the negative battery pole wire. Not enough current was going into the driver side due to bad grounding if that's a word....Hope this makes sense...it worked for me jebfrank 11-29-05, 06:58 PM I just purchased some projector lamp headlights for my 99 Cat They look great compared to the yellowed stock headlights. Here is my problem. Ok I installed the passenger side headlamp first. installed the bulbs, plugged in the harness and let there be light. beautiful. worked like a charm. Well that was simple enough so now we move on to the driver's side headlamp, installed the bulbs and plug in the harness and turn on the headlights ... well i am getting very low output from the driver's side and also both the hibeam and lowbeam on the passenger side are now lit up :banghead: What on earth is the problem. Am i running into a short somewhere. I know its not rocket science but am i missing something? Its funny cause my friend said oh it shouldnt take that long to change them. I said yeah it shoiuldnt but nothing comes easy on the catera. Any help would be greatly appreciated thanks.
Do you have a picture of what these lights look like in your 99? I have projectors on my 04 Goat and I have been thinking about doing them in my 98. NolaBoy 12-19-05, 07:01 PM This might sound weird but I had the same problem. I bought mines from Germany as well. I took one of the ground wires from the old headlight, (brown wire), removed the original ground from the new lamp, just off the groove that it is attached to and connected the one from the old lamp to where the ground wire was positioned on the new headlight. Then direcectly connected the other end to the negative battery pole wire. Not enough current was going into the driver side due to bad grounding if that's a word....Hope this makes sense...it worked for me
Hmmmm very interesting. I will have to try this. Thanks alot NolaBoy 12-20-05, 11:25 AM jebfrank
there is a pic of how they look in this guys ebay auction
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=8023040185&sspagename=ADME:B:AAQ:US:1http://pics.ebaystatic.com/aw/pics/s.gifhttp://pics.ebaystatic.com/aw/pics/s.gif NolaBoy 12-20-05, 11:29 AM This might sound weird but I had the same problem. I bought mines from Germany as well. I took one of the ground wires from the old headlight, (brown wire), removed the original ground from the new lamp, just off the groove that it is attached to and connected the one from the old lamp to where the ground wire was positioned on the new headlight. Then direcectly connected the other end to the negative battery pole wire. Not enough current was going into the driver side due to bad grounding if that's a word....Hope this makes sense...it worked for me
the ground that you are talking about. is that the one located by the low beam bulb. what i am getting is you attached another ground wire to that location and ran it directly to the battery. am i on the right track here?? Thanks NolaBoy 12-20-05, 04:38 PM Alright i ran that ground directly to the battery. All is fine now. Everything is working fine...EXCEPT:banghead: ... The only thing that is not working like it should is the daytime running light on the passenger side. Driver's side comes on when the car is in drive but it looks kinda bright like its more than 50% voltage, however the passenger side does not illuminate. I have swapped bulbs, checked fuses and relays and nothing. I have also ran a ground directly from the passenger side to the battery. One step closer just to take one step back. The hibeams work fine when i turn them on. What could i be missing??? stevehogan 12-20-05, 07:24 PM By running grounds from each headlight high-beam back to the battery, you have effectively disabled the DRL wiring. The DRL relays hook the high beams in series when in DRL mode i.e. the "ground" from one bulb is hooked to the "hot" from the other. You need to get a copy of the schematic for the headlamp wiring to see what I mean. I am not home or I would post a PDF. Perhaps one of the others here can post the schematic vogel81 12-21-05, 01:29 PM I experienced the same problem with the same lights. They are euro-spec and not wired correctly for the Catera. I had to switch a wire in the driver side headlight. I don’t remember which one for sure, but I was able to look at my old headlight, and in comparison with the new, I was able to figure out which wire was incorrect. NolaBoy 12-21-05, 05:51 PM I experienced the same problem with the same lights. They are euro-spec and not wired correctly for the Catera. I had to switch a wire in the driver side headlight. I don’t remember which one for sure, but I was able to look at my old headlight, and in comparison with the new, I was able to figure out which wire was incorrect.
yep i just finished rewiring the headlights to spec. everything works like a charm. I have the instructions for rewiring in a document that someone sent me. Step by step and very easy to follow. If anyone wants it I would be glad to send it to you just let me know. I appreciate the help fellas bengsxr 12-27-05, 05:00 PM hey nolaboy can you email me the instructions for this cause I just ordered me a set of those headlight that way I will have the instuctions in hand when the lights show up. bengsxr@yahoo.com thanks for the help NolaBoy 12-28-05, 12:57 PM hey nolaboy can you email me the instructions for this cause I just ordered me a set of those headlight that way I will have the instuctions in hand when the lights show up. bengsxr@yahoo.com thanks for the help
coming your way bengsxr 12-28-05, 03:48 PM thanks alot I got it NolaBoy could you send me the document also? Please mail it to CtA318@gmail.com
Thanks in advanced. NolaBoy 12-29-05, 02:04 PM NolaBoy could you send me the document also? Please mail it to CtA318@gmail.com
Thanks in advanced.
check your mail Hello NolaBoy & bengsxr:
Would either of you mind sending these wiring instructions to me? I, too, have had some minor issues with my newly-installed lights.
tbs100@hotmail.com
thanx a mil! bengsxr 12-29-05, 04:24 PM i will kmcatera00 12-30-05, 02:47 AM Does anyone know where I can buy these projector lights for my 2000 Catera? What website do I go to or who do I contact? I have seen them on eBay but I thought if I contacted the supplier directly I might get a better price. Thanks - kmcatera00 bengsxr 12-30-05, 08:36 AM go on ebay there are a bunch on there. |
