View Full Version : Cadillac parts
ej2000n
10-10-05, 07:14 PM
I have a 97sts that has a small crack on the coolant tank where the hose connects which runs across the top of the motor. there only seems to be a problem with it if the AC is not on. For some reason. I've tried to use the JB weld but it peeled of cause of the heat and the coolant pulses out through the crack which has now stained the battery with the orange color. The dealer quoted me a price of $92 for the tank and $45 for the labor. I know this is a cadillac but that seems a little outrageous for a plastic tank which sits out in the open. Is there anywhere I can find this part so I can do the job myself, I've searched but came up with nothing.
Dadillac
10-10-05, 07:34 PM
www.gmpartsdirect.com
www.rockauto.com
www.gmmotors.com
I hope one of these will be to your liking.
Don
Ranger
10-10-05, 10:32 PM
Funny you should mention this. I had a hairline crack in the same place about a month or so ago. JB Weld worked for me........ so far.
Supercrew632
10-11-05, 02:41 AM
45 dollars labor is only 1/2 hour flag time to the tech. $140 for insurance against destroying your engine is a small price to pay. An engine is over $9,000.00---ask your dealer
Supercrew632
WarrenJ
10-11-05, 03:38 AM
I sorta get the drift, but could you explain "flag time?"
Regards,
Warren
Pjs
10-11-05, 07:03 AM
My tank cracked right under the hose inlet as well. I paid $100 for a new tank to be installed on the radiator. I surmize just the heat from the return water is hot enough to distort and weaken the plastic as most of these radiators all seem to crack in the same place.
