View Full Version : 97 STS, low compression in all left bank cyls
jkk
10-08-05, 06:05 PM
The car I'm looking at is a 97 STS, 111K, $3K. Car was in this shop for head gasket job; they sent block/heads out for repair ($800 !), then they gave car back to owner. Owner drove it for 2 weeks, then had it towed in with 'no power' complaint. Since owner had not and could not pay for first repairs, service shop became owner. They're selling to recoup their $$.
So I looked at car and it's great in/out. Engine ran, real rough at first, no response to acc pedal at all. Sounded like exhaust manifold leak, misfires. Had to start it 3-4 times (trying to warm it up for compression test). I was able to rev up a bit, and engine ran a lot smoother, very little smoke at pipes, still heard what sounded like exh leak. No big knocks frmo bottom (good news, I hope).
I did a comp test; found ~210 PSI (120 on first stroke) on the right (rear) bank, and 180,170,180,160 PSI (90 on first stroke) on the left (front) bank. When I tested the front 4, there was a 'pop' noise during each turn of the engine. But when I tested the rear 4 (all ~210PSI), there was no pop.
So, I think the front head is loose (or big time gasket malfunction) since all 4 cylinders read low and each cylinder produces the pop sound during compression testing. I have to wait until Monday to learn exactly what the machine shop did (helicoils? Timeserts? All holes, or just some holes, etc.).
My first question is: Can I get a shop to timesert the left (front) bank while it's in the car? Or is that a foolish thought? (I'll look for a different shop, unless the first wants to do it for free and I can find someone who can vouch for this shop's expertise in N*.)
2nd question. Assuming I pull the engine, what do I do with the right (rear) head. Leave it on? If I have to take it off, should I get those holes timeserted if they weren't done before? I know other threads suggest doing all holes if you're doing one, but the head is working great as is.
Your replies are much appreciated.
zonie77
10-08-05, 06:20 PM
First, this is the wrong section for questions. It's for tips. Ranger will probably move it to the N* section.
I'd ask the shop whether they timeserted all the holes. Then I'd remove the front head and see if they really did. I would also pay attention to the tightness of the headbolts. It's possible they missed one whole tightening sequence and under tightened. You'd have to replace the bolts and gasket again.
If all the holes were timeserted I'd leave the back head on and cross my fingers.
We got interupted on one by a phone call and weren't sure where we stopped, so we redid them all (which is OK). It's possible the mech got interuppted and mised a tightening sequence. You can't really check that.
EcSTSatic
10-08-05, 06:29 PM
With the popping. misfires. power loss etc, it sounds like they didn't get the cam timing set right when they fixed the head gasket. Or it slipped.
jkk
10-08-05, 09:59 PM
First, this is the wrong section for questions. It's for tips. Ranger will probably move it to the N* section.Ok, sorry. I wasn't sure, as I did see other qs here.
I'd ask the shop whether they timeserted all the holes. Then I'd remove the front head and see if they really did. I would also pay attention to the tightness of the headbolts. It's possible they missed one whole tightening sequence and under tightened. You'd have to replace the bolts and gasket again.I'm calling them Monday morning. If this is all I need, I'll be one happy dude.
We got interupted on one by a phone call and weren't sure where we stopped, so we redid them all (which is OK). It's possible the mech got interuppted and mised a tightening sequence. You can't really check that.If the bolts are tight when I remove them, and the timeserts are there (what do installed timeserts look like?), I'll replace the gasket and bolts and fire her up. This should cover a defective gasket (unusual?) or incorrect tightening. What else could have caused this - more overheating that was not fixed before or after the head work?
If the holes were not timeserted, is it possible to timesert the front headbolt holes with the engine still in the car? This would obviously save a lot of work. (I did a Helicoil on a 1984 Buick Electra wagon - engine still in the car - with a busted headbolt - worked great).
jkk
10-08-05, 10:26 PM
Oh - forgive my apparent ingratitude. Thanks for the quick replies and the great info. Although I've already given a small amt to maintain this site, I've decided that if I buy and then sell this car, I'll donate 5% of the profit to this site. Hopefully that will be more than a few $$.
jkk
10-08-05, 10:59 PM
Thanks for the reply!
Well, it ran for about 2 weeks with no problems, so they must have initially set it right. I'm hoping these symptoms are purely due to the 'loose' head.
But, now that I've thought a bit more, if it ran OK for 2 weeks, doesn't that mean that the head was correctly installed? Or, maybe the gasket held for 2 weeks under bad install conditions, and then finally failed?
zonie77
10-09-05, 01:23 AM
A timeserted hole looks different than a stock hole. Look at the timesert website. Look at the N* head gasket thread in this section for timesert info.
I agree that cracked or warped head shouldn't effect all 4 cyls the same (assuming it ran well at first). Cam timing shouldn't have jumped unless the chain guide came loose. Slim possibility.
Are you familiar with tightening procedure? 30ft/lb, then 70deg,+70deg,+70deg (I think). Since you're not using a torque wrench you have to measure the amount it turned (gauge available at Azone). If you goof and miss 1 series you left them very undertorqued. If the mech got interupted he might've missed 1 sequence and not realized it. I'd give that the most likelyhood.
You can do this in the car but the cam timing is hard to do with the limited room.
You must use new bolts too.
You could try just tightening the bolts and see what happens (see how tight they are,then loosen and redo tightening procedure). If they all retighten and it runs good you know what's the problem. I'd still replace the gasket and bolts but you would have verified the problem! If any won't tighten you've got a thread problem. :thumbsup:
jkk
10-10-05, 10:40 AM
Are you familiar with tightening procedure? 30ft/lb, then 70deg,+70deg,+70deg (I think). Alldata says 30, then 60,60,70. But I think I remember seeing a change to that - I think the initial 30 was dropped to the low 20s ?? I can't recall where I saw this. Help anyone?
You could try just tightening the bolts and see what happens (see how tight they are, then loosen and redo tightening procedure). How do I 'see' how tight they are? Is there a certain torque 'range' that properly tightened bolts will meaure at? Should I just try torquing to - 75 (a safe number?)- and then call them tight if they don't move?
If they all retighten and it runs good you know what's the problem. I'd still replace the gasket and bolts but you would have verified the problem! If any won't tighten you've got a thread problem. :thumbsup:Need your opinion in this: I guess if I'm going to replace the bolts and reassemble to test, I may as well remove the head, inspect the holes, change the gasket and bolts, and then bolt everything back together. I think the only extra step is to lift the head and put in a new gasket. It's one less tightening sequence on those head bolt holes, which sounds like a good thing to me. I won't know for sure it was 'just' loose bolts but I'll settle for knowing it was either 'loose' bolts or bad gasket (which I can at leats visually inspect, right?).
zonie77
10-10-05, 12:41 PM
Did you disassemble it? My suggestion to tighten the bolts assumed it was still together. That would let you confirm it was just loose bolts without a lot of work.As far as tightening them to some torque value for a test, sure 75 lbs would be about right, for a test I'd probably just go 60. This is for a test. I'd do the correct tightening seq for the new bolts.
Once the bolts are heatcycled more than a few times they must be replaced.
If the bolts were loose but the threads good I'd try replacing the bolts without replacing the headgasket. We had a Caddy engr on here before and he even said that the plant does that on test engines. A new gasket should still be resiliant enough to handle that. If that happens you should run out and buy a lottery ticket!
(I heard that the 99's and 2000's had that problem and guys at the dealerships were grabbing them and changing the bolts without changing gaskets. Just a rumor from a Caddy employee I dealt with)
The tightening seq I gave was from memory, that's why I put (I think) next to it.
Testing the bolts (if they are soooooooooo loose the head is lifting on compression) should be obvious with a ratchet. If you need a breaker bar they are probably not be the problem.
dkozloski
10-10-05, 01:23 PM
I'm betting on a cam timing issue.
mcowden
10-10-05, 03:48 PM
That's what it sounds like to me, too. Where you been hiding, dkozloski?
chevelle
10-10-05, 04:16 PM
Since this whole thing started with the teardown and it affects an entire bank of cylinders I am betting on a cam timing issue also. Hard to visualize a head gasket affecting all 4 cylinders like that.
It is somewhat easy to check the cam timing. Number 1 is on the right front corner of the engine. Passenger side, rear bank. Take the plug out. Stick a wooden dowel down the spark plug hole and turn the engine until you find TDC when the dowel stops moving and reverses direction. Take the front cam cover off or loosen it enough to lift the front end up. The cam timing marks on the sprockets should be at 12:00 relative to the cam cover sealing surface of the head. Look at the cam sprocket marks and timing slots. The slot on the pin of the intake (inboard) cam should have the LI marks by it (left intake...get it??) and the exhaust cam sprocket should have the timing slot marked LE over the timing pin of the exhaust (outboard) cam. If the marks are at 6:00 then the engine is at TDC exhaust. Turn it one more time to check the timing. The sprockets are identical and installed on the intake and exhaust cams per the LI and LE marks. Maybe they just got them mixed up.
The owner may have not know the difference when they got the car back that it wasn't running right until they drove it awhile and then wouldn't pay because the repairs did not go right.
You need to quiz the shop about the work done. They would know if they installed timeserts into the head bolt holes or not. If they cannot answer that question or do not know what timeserts are or used helicoils then walk away.
Ask them if they pulled the heads off without taking the front cover of the engine off. To reset the cam chains correctly the front cover needs to come off...if nothing else to reset the cam chain tensioners.
If the car ran OK for awhile and then started this possibly they let the cam chain tensioners rachet out when they took the head off and then FORCED the cam chains back onto the sprockets. This would eventually cause failure of the cam bearing, front of cam, sprockets, guides, chain, who-knows-what.
In a deal like this it is impossible to predict what you are getting into. With an independent shop working on an engine that they may have had no previous experience with anything could have happened. In any case, assuming it is the head gasket again is a bit premature and unlikely in my estimation.
Ask the shop if they have a service manual for the engine. That might be the first clue as to whether the repairs can be relied on or not.
In any case, sounds like a potential $$$$$$ nightmare to recover from what they have done. Replacing a head gasket and timeserting the head bolt holes is not that difficult a task, really, if you can read and follow directions.
jkk
10-10-05, 04:30 PM
Here's an update;
Zonie77: It's still assembled, sitting on the repair shop's parking lot. I'm still trying to decide if I should buy it. The repair shop's owner and mechanic have been really helpful, understandably so since I think they're trying to get paid for their work changing the head gasket and the $750 they paid for machine work.
Let me setup the original scenario: Original problem was with the front head. They fixed it. Mechanic said this was the second time to have the head bolt threads fixed and they used the bigger inserts (from GM). Owner drove it for ~2 weeks, came in with "loos of power". Since owner had not paid for previous work ($3K), the service guys just parked it on the lot. They never even read codes or did a compression test. They'd just like it gone. They gave him 1-2 months to pay. Since he didn't, he gave them the title. They're selling it to recoup their investment.
I'm encouraged to hear the timing comments from dkozloski and mcowden. This is why.
I just saw the car again 2 hours ago. I asked them to scan for codes - all we got was an ICM ground code error (or fault?) on his scan tool (red box). Then we couldn't scan anymore as his scanner wouldn't connect again. He couldn't figure out why.
Also, I was thinking more about the compression test I did. Results were ~210 PSI (120 on first stroke) on the right (rear) bank, and 180,170,180,160 PSI (90 on first stroke) on the left (front) bank. Although these are lower than the rear and somewhat unsettling since this head was the original culprit, the numbers don't have to be caused by a headgasket, do they? Would the timing issue lower all 4 readings, or should it lower some and raise others? How can I discern - before I give them $3K - that it's most likely an ignition (timing) issue and not a head gasket?
thanks.
EcSTSatic
10-10-05, 07:05 PM
A timing issue will drop the compression on all cylinders because the valves are not closing competely on the piston's upstroke. Also, your ignition will fire at the wrong times causing "popping" sounds because the valves are not sealing the chamber.
That's why that was the first thing to come to my mind when you mentioned the symptoms. (see third post)
There should be alignment marks on the cam sprocket to help you determine if it is right of not.
zonie77
10-10-05, 07:13 PM
thanks.
We are talking Cam timing, not Ignition timing.
Cam timing could effect one head as each head has separate cams.
All the guys betting on cam timing could be right. It wouldn't be that hard to fix if nothing was damaged. Even if a chain or tensioner was ruined they aren't that hard to change. You check the cam timing with the valve covers off. I think you could do it with the timing cover still on.
Supercrew632
10-11-05, 03:21 AM
Run like hell and keep your money----I am a dealer technician and if this one has already been done twice, it is finished---When we do them, once the timeserts(and then the bigserts are used) they only hold for a year and are back for more. If this one has been done twice you would catch hell when removing again and half of them pull out. Just trying to save you the headache---Not worth the money or trouble in my opinion and I know how to work on them and wouldn't take this car if it was given to me.----Just my .02
Supercrew632
jkk
10-11-05, 08:31 PM
... wouldn't take this car if it was given to me.----Just my .02
Supercrew632
Well, thanks for your $.02 cents worth. I'll send you your change.
Maybe you're being a bit sarcastic/rhetorical, but good grief, If I was given this car, I could part it out and make enough money to make it more than worth my while.
"It" is not finished, meaning the car. The block may very well be headed to the recycler. But I've already located 2 engines ($350, $150), with very good chances that the blocks are usable.
Besides, I'm encouraged by it being a possible timing issue, mentioned previously.
I bought the car this morning. Maybe I'll drive it out to Vegas sometime.
zonie77
10-12-05, 01:48 AM
Keep us informed!
I'd make a point of getting the factory svc manuals. Usually on ebay for $40-50 range. Even if you don't get the exact year they are helpful. I would try to get the year one one of the 2 you have though. Mostly the wiring is different. The intakes between your 2 also.
Supercrew632
10-12-05, 02:10 AM
Sorry, Didn't mean to rain on your parade---If you find a GOOD used engine than fine---I have worked on these northstars enough to know that they take more work than they are worth when they get a few years on them. I agree that 1997 sts body style is SMOKIN'---one of the best I have seen---If you like the car and it is in great shape--it is probably worth restoring---I was just stating that through my experience at the dealership level is, we submit claim to extended warranty recommending new short block due to head bolts pulling out, they say "we are only going to pay for timeserts" Ok, so that gets done---8 months to a year later the timeserts pull out, customers block is junk(because we will not do them twice)--now they are out of warranty and have to pay over $9,000 plus labor fore a new engine. Sadly most of them take their car and get rid of it. I guess I have just worked on them so long, that I have a BAD taste in my mouth so to speak----Granted I like the cars, but would opt for a 4.5 or 4.9 liter---you can't go wrong with cast iron. Sorry this is so long, I am maybe just stuck in the past. Good luck on your car and if you ever need any help with repairs I may be able to help---I know its not the same year, but I have a set of 1998 seville manuals that might help---let me know---SUPERCREW632
peteski
10-12-05, 02:22 AM
So, the timeserts can pull out too? That is a news to me. I thought those were rock solid (if installed properly).
Peteski
jkk
10-12-05, 04:25 AM
Keep us informed!
I'll be posting updates as I get to this one. Just finished pulling a head off of a 97 Taurus. (Can anybody help me out with this one - I can't seem to figure out what went wrong here; see attachment... )
I've already ordered the manuals; I just missed a set on eBay so I ordered a set from factoryautomanuals. I also have the Haynes; they're a lot better than they used to be (1970's).
Still haven't decided if I'll lift or drop the engine (if it has to come out).
jkk
10-12-05, 04:38 AM
Sorry, Didn't mean to rain on your parade---If you find a GOOD used engine than fine----SUPERCREW632 No rain felt here; I was admittedly messin with ya some. I will keep looking for a good used engine because I'm in no big hurry. If I don't find one, I'll have 2 engines (96 Deville, 85K miles - actual since I know the car it came out of and a 94 Seville, haven't seen it yet but it's still in the car and runnning) that I think will provide me a usable short block that I can timesert and then swap with the original 97 STS block.
Seems to me that dealer techs (Cadillac, Ford, Dodge, etc) are a lot like docs and nurses who work in intensive care units at the hospital. All they see are the most ill, many of whom die. It's easy to lose perspective. Just my $0.02 worth .... (keep the change).
zonie77
10-12-05, 11:18 AM
JKK, I know what's wrong with that Taurus! Someone's been pouring coffee with cream in the engine!!
You just gotta switch to black coffee!
I've mentioned in a couple of posts that Caddy's aren't the only ones havn problems.
zonie77
10-12-05, 11:20 AM
Because of the smaller size, therefore easier accessability, I've pulled Taurus's from the top.
jkk
10-12-05, 01:33 PM
Humm, that explains the oily taste in my coffee cup http://cadillacforums.com/forums/images/smilies/coffee.gif
jkk
10-12-05, 01:37 PM
Because of the smaller size, therefore easier accessability, I've pulled Taurus's from the top. I plan on leaving this one in; no damage to cylinders, compression was great in the other bank. Hope to get away with minimal time on this one. Still have to check for warpage though ...
chevelle
10-12-05, 09:51 PM
If timeserts are "pulling out" then whoever is installing them is not doing something right....sorry, but the timeserts have proven over and over again to be bulletproof. I have not seen nor heard any reports on here or other forums from other installers having problems with timesert repairs failing.
Are the timeserts in question the "Northstar headbolt" specific timeserts or are you using generic timesert repair inserts. The Northstar inserts are longer and made specifically for the Northstar head bolt repair by timesert. The shorter (and cheaper....) generic timesert inserts do not have enough engagement on the OD and will pull out.
jkk
10-12-05, 11:54 PM
Until I investigate (i.e. rule out) the cam timing issue, I won't be pulling the heads to check the headbolt block threads. Obviously, I'm hoping that it's a cam issue. I was told by the service dude that the machine shop installed the 'large' GM inserts because it already had been 'serted once. I think I'll call the machine shop myself after I take possession of the car on Friday or next Monday. (I had asked the current service guy for a copy of the work done by the machine shop, so I've got their contact info.) Since they make the 'bigserts', I guess that could imply that the smaller ones have failed. Although I guess they could have originally been made for another application/vehicle and the bigserts are used on Cadillac blocks that had the normal inserts installed incorrectly.
So, I'll do some old fashioned cramming and learn how these N*s do cam timing. This will be my first OHC engine - a DOHC at that. So, I've got some learning to do.
chevelle
10-13-05, 04:23 PM
Uh....did you read my post above. That is a very simple version of how to check the cam timing that will work fine. Definitely bone up on the service manual version and how to time the cams from scratch but the abbreviated version will tell you if the cams are off on that side.
zonie77
10-13-05, 07:18 PM
Definitely start by checking cam timing and bolt tightness. Don't tear anything apart without checking those 2 things.
jkk
10-14-05, 09:56 PM
Uh....did you read my post above. That is a very simple version of how to check the cam timing that will work fine. Definitely bone up on the service manual version and how to time the cams from scratch but the abbreviated version will tell you if the cams are off on that side. Yes, but only briefly. The steps seem simple enough. I should get the car into my garage late next week and this is the first thing I'll try.
Thanks again.
Supercrew632
10-15-05, 12:50 AM
Timeserts do pull out, and since I work at the dealer only GM serts are used---aftermarket crap is not even considered. GM has banned us from using the "BIG" serts for warranty repairs, so they quit ordering them. So that said, we cannot even use them on paying customer's engines. The serts we use have special tools and drill bits with collars and a guide plate to be sure they are straight. They are installed correctly---nothing is bulletproof---all a customer needs to have is a coolant leak elsewhere, overheat once and they are done, just like if they weren't there. I do believe that the "BIG" serts are better, but we cannot use them because GM said so, and so the dealer wrote them off. I have seen the "big" serts hold indefinitely. In a bulletin we received, GM said the size of the holes that had to be drilled to accomodate the "BIG sert" comprimised the integrity of the block and they had blocks cracking across the nation.
JKK----yes we are like the docs and nurses you talk about, we only see when the cars are messing up, so sometimes we get a little biased. Thanks this is a great thread.
Supercrew632
