I will be adding a hefty amount of weight on the rear due to add an audio system.
I am already running on 30" inch rims with 255/30/30 (I had to do some cutting on the inner wheel well plastics)
When I hit a hard bump I feel the tires scrape just a little bit against the inner plastic (have to do a little more cutting I guess)
Overall, I want to lift my 2007 escalade esv 3" inches (if that's enough) in order to add the music system.
If I do lift it 3" inches, with the weight added would it level back to around the same height as is right now?
And is this lift good enough?
http://www.ebay.com/itm/Air-Lift-60...Parts_Accessories&hash=item5d456eb56c&vxp=mtr
Any help is highly appreciated. Thanks.
PS: also, it says "Will not fit models with factory auto leveling option" and I have no idea if my car has that.
