Hello, I own a 2008 escalade. What do I need to be able to get my iphone to sync with the escalade so I can actually listen to my music from my iphone in my escalade?
you need isimple module and you will get Bluetooth audio, phone, USB audio IPODs, flash drives etc. also you will get the traditional 3.5mm for the headphone jack or if you have the rear av jack on the back controls you can do it easy for 20$ from radio shack and select aux on radio
You cant do Bluetooth unless you do some modification work, but you can use a 3.5 to RCA wire and connect when you want to listen right away or you can go the isimple route but requires installation work but best buy does it now so that is a good thing, I paid 250 installed at best buy, now I have USB drive, Bluetooth, 3.5mm wire and phone also.
To avoid electrical issues related to unlocking/starting the truck with Isimple installed, remember to shut off the radio by hitting power button on the radio before shutting off the engine
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
