Capt Fiero
09-30-05, 01:26 PM
This forum has a nice sticky with code info. Which is great, but I do own a scan tool and it tells me the same stuff.
My problem is understanding what that stuff really means.
I am getting a master reset code and a short in the fuel pump circut error.
I saw it someplace that stated what pin to check on the ECM for each code and a brief description on what each code was caused or set by. Now I can't seem to find the darn thread or page.
If anyone can help direct me to that page. In my best Roger Rabbit P-P-P-P-P-LEASE!!!!!!!!!!!
smacks head for not saving the link.
TIA
Capt
They're back! It's back here near the top of the page.
Thanks David Smedley! :thumbsup:
DaveSmed
09-30-05, 04:09 PM
Would the master Reset be an E52 by any chance? If so, did you disconnect the battery recently?
I need to look up the fuel pump one though. I remember that circut was kinda odd, with redundancy through the oil pressure switch and whatnot.
Capt Fiero
09-30-05, 05:27 PM
Ok here are all the codes in order
19 Shorted Fuel Pump Circuit had this one for a long time.
54 Idle Speed Control Problem (I think I accidentally triggered that when I was trying to do the idle learn procedure)
53 Distributor Signal Interrupt --- Never seen this one before
52 Keep Alive Memory reset (yes I had the battery off about 40 miles ago
For reference I am using an Auto X-Ray 240 Scan tool P/N 705-0001-001A
Capt Fiero
10-02-05, 04:05 PM
Just an update, the distributor signal error turned out to be, a loose ground on the MSD 6AL box. Only thing holding the wire from completely falling off was the shrink tube I put on all my connections.
I used the scan tool to clear all the codes and made a couple of new ground straps and all seems to be fine now for the moment. I will update you guys and let you know how it goes in a week. I am going to have to replace the O2 sensors in hopes that it fixes the low response times.
Capt Fiero
10-04-05, 04:50 PM
Hey Kev, you still around.
The link at the top shows the problem associated with each code. However what I am looking for is a slightly more in depth guide.
I know code 19 is fuel pump circute, but what I am looking for is what PIN on the ECM that code refrences too.
There is something about needing a positve 12v suppley to that pin on the ECM, but for the life of me I can`t find an online refrence to that pin.
P.S. I clreaed the codes and have driving it 200 miles the code 19 came back almost instantly.
DaveSmed
10-06-05, 07:11 PM
http://mywebpages.comcast.net/davesmed/chart.gif
http://mywebpages.comcast.net/davesmed/diagram.gif
Hope these help you out!
Capt Fiero
10-06-05, 07:25 PM
DavesMed you are a GOD, Thank You
