: Mid America Motorworks CAGS Eliminator
GOTTSPD
09-25-05, 05:16 PM
Anyone try this CAGS eliminator from Mid America?
http://www.madvet.com/shop?frame=1.101
Part 603-703.
My dad bought it for the V and for some reason had trouble shifting into reverse putting it in. After he took it out, no problems getting to reverse.
Seems like it's a pretty simple little thing, so it's hard to imagine that it wouldn't work, so I'm curious if anyone has any input on this.
Getting another one is an option, but if I can get this to work without any fuss, no reason to buy something else...
CVP33
09-25-05, 06:35 PM
Check the FAQ's and make sure you used the right harness. There is one on each side of the trans as I recall. Picking the wrong one causes the symptoms you described.
ctsvett
09-25-05, 06:36 PM
the !cags for rick is great.. No problems with reverse at all and the tech didnt even see it on my car until I pointed it out (and thats with the tranny on the bench!)
www.stealthv.com
Reed
6104696
09-25-05, 07:48 PM
there can be only one. www.stealthv.com (http://www.stealthv.com).
buying it and putting it on per his instructions will ensure success.
Any other brand is just a poser.
GOTTSPD
09-25-05, 08:01 PM
I understand that folks like the StealthV one, but lets focus on this one. CVP33, with regard to your suggestion that it may be plugged into the wrong harness, wouldn't that mean that it wouldn't eliminate the skip shift function?
In my dad's case, it did eliminate the skip shift, but it made reverse hard. Look forward to yours and others replies.
6104696
09-25-05, 08:31 PM
Sorry, my bad. Step one: get under car, remove mid america unit, reconnect harness. Dispose of ind america eliminator in suitable trash receptacle. Test reverse. If problem persists, see dealer. If problem is eliminated, the obtain stealthv !CAGS unit, and install per his instructions. If reverse problem returns, then something is truly funky. And, yes while the above is tongue-in-cheek, the skip shift harness has nothing to do with the reverse lockout, unless I am missing something; they are on different circuits, so even the inferior mid-america cags eliminator should have no effect on reverse. That having been said, if the resistance is set wrong on the inferior CAGS eliminator (or even a superior one) you should get an error code which could (though shouldn't) confuse the system.
steve711
09-25-05, 08:39 PM
Mid America :tisk:
StealthV :thumbsup:
ctsvett
09-25-05, 08:46 PM
It sounds like it may be installed incorrectly..... Does the mid america piece even have the right connector? I looked at the website and it looks like it might be close, but not sure...
If you lost reverse, than you unplugged the reverese lockout.
Reed
GOTTSPD
09-25-05, 10:41 PM
He didn't lose reverse entirely, it was just hard to get to. Not just syncros not lining up hard, but really hard. Then after taking it out, reverse magically became easy to get to again. Also, it did eliminate the skip shift. Would you be able to get to reverse at all if the reverse lockout was unplugged?
FWIW, I have never seen this device in person (heck, I've only seen the car a couple of times a year ago).
ctsvett
09-25-05, 10:51 PM
a 2 ohm resistor should not affect the operation of the snychros...
Reed
jimbo1320
09-26-05, 08:47 PM
I called and asked if it would work in the "V". No it doesn't so I bought one from Rick. Works great, want to by it $30.
Jimbo
jrcirillo@adelphia.net
c4racer
09-26-05, 09:00 PM
So the V must be looking for a different resistance value than the vette? Anyone know what value R is needed?
Scott
benjet
09-26-05, 09:06 PM
Scott
Different plug (connector) than the vett, same 2.2k resistor works.
Leeman
09-26-05, 09:40 PM
Still amazes me people pay $35+ for a $0.15 resister.
-- Lee
GOTTSPD
09-26-05, 09:43 PM
Seems like it's the same connector? Again, I haven't seen the parts or the car, but my dad said the mechanic connected the connections. What makes you say that the connector is different?
StealthV
09-26-05, 10:58 PM
The Corvette is different else the !CAGS Eliminator wouldn't exist.
