mdogg1950
09-23-05, 04:31 PM
Does the 1990 4.5L have the EGR tubes referred to in previous post? If not, what is the procedure for cleaning it?
| View Full Version : Cleaning '90 EGR 4.5 mdogg1950 09-23-05, 04:31 PM Does the 1990 4.5L have the EGR tubes referred to in previous post? If not, what is the procedure for cleaning it? chevelle 09-23-05, 10:11 PM Yes. Remove aircleaner. Hold throttle blades wide open and look down the throttle bores with a strong light. The tubes sticking up at you (below the throttle plates) from the floor of the intake manifold are the EGR tubes. Use a piece of stiff wire to rod the deposits out of them all the way thru down to the passage below. Simple and easy. | |
