Deezy444
09-23-05, 01:36 PM
How Important is the Tensioner Pulley And how do i know if it is working or not also does anyone know where to find the correct way to wire the serpentine belt?
| View Full Version : 88 Deville.Tensioner Pulley. Deezy444 09-23-05, 01:36 PM How Important is the Tensioner Pulley And how do i know if it is working or not also does anyone know where to find the correct way to wire the serpentine belt? brougham 09-23-05, 03:51 PM Well it's what keeps the belt tight so it's pretty important. There should be a sticker under the hood that shows how to put tbe belt on and when you buy a new one it should have pictures for it on the back of the box too. kingphil69 09-24-05, 09:45 PM on the 88, sometimes it's necessary to remove the vaccum pump hose ( the metal rod that gets in the way) to replace the belt. correct way is right on the radiator above the "correct ac charge procedure" sticker. hotrodpaully2 09-30-05, 12:00 AM well to know if Tensioner is working is if it keep belt tight and when you pull up on it to relase tension (Like what you do when change belt) it moves it working but if it not keeping belt tight or it doesnt move when you try to move it it bad | |
