: 2005 STS Camshaft Sensor Location? V8 4.6 engine
candy0815
05-29-14, 10:19 PM
Does anyone have a diagram or photo of where the camshaft sensor of a 2005 Cadillac sts v8 4.6 engine is at? Please help!!!
Submariner409
05-30-14, 09:10 AM
The CMP (CaMshaft Position sensor - the Acronyms sticky ^^) is bolted to the front of the right cylinder head directly in front of the exhaust cam sprocket. If you suspect that it is faulty, a connector and wiring check should be the first order of business.
In this drawing the engine is partially disassembled .....................
04GrandAmGT
05-30-14, 10:50 AM
he has RWD Northstar, is it still the same? cause i know when they updated the FWD in 2006 the cam sensor got moved to the intake cam.
Submariner409
05-30-14, 12:51 PM
Yeah, quick trigger finger. In any case, the CMP reads a cam sprocket pulse.
maeng9981
06-01-14, 03:20 AM
It's at the camshaft position actuator solenoid housing. Visible with the beauty cover off.
http://i.imgur.com/IYiq3OR.png
candy0815
06-01-14, 06:44 AM
Ok thank you for the info!
dawgy2219
06-19-14, 01:41 PM
Does anyone know about how much the dealer charges to reprogram the CPS after a self install? I heard this needs to be done in order to operate properly.
jacobj
05-07-16, 07:34 PM
Which one is camshaft sensor in picture ?
jacobj
05-07-16, 07:35 PM
Which one is CPS? Left or right?
maeng9981
05-08-16, 04:36 AM
There are 4 camshaft position sensors on a RWD. So you are seeing two camshaft position sensors in the picture. The upper one is the intake side, and the lower one is the exhaust side.
20grand
07-21-16, 05:37 PM
Does anyone know which is A and which is B?
