View Full Version : Help needed - 61y Cadillac engine intake manifold
Martin460
09-21-05, 05:04 PM
Does the particular text (see the link) correspond to the picture above it?
http://community.webshots.com/photo/452433503/452435527MhatLE
How the valve could be removed from the manifold?
Thanks in advance,
Martin
The Ape Man
09-21-05, 05:14 PM
The text matches the picture but the valve is not located in the manifold. It's after the exhaust manifold. They are showing the flow of exhaust through the intake manifold which heats it up.
Martin460
09-22-05, 02:43 PM
Thank you The Ape Man.
I'm still confused....
I have drawn the red arrow myself and I'm interested in finding out which detail it is pointing at. I thought I've pointed at the valve.
Martin
Chrome
09-22-05, 03:53 PM
I believe what you are pointing at is the choke heater tube...
The Ape Man
09-22-05, 06:59 PM
I agree. Can't be sure with that picture. That would be a pipe that goes into the heated portion of the intake. It allows the choke mechanism on the carbonator to pull hot air and warm the choke thermostat.
