JLM5151
09-18-05, 07:35 PM
Doors unlocked fine and got into the car, went to start it and the main cluster lights come on, but the radio and climate controls will not. The car will not turn over and now the power and remote locks will not work. Also the readings will not display correctly, gives me an X before all of the readings such as oil life, tire pressure, battery, trans fluid. Could this be a fuse since some things are working and some aren't. Any feedback will be appreciated... Thanks
Lift the rear seat cushion and inspect the battery terminal connectors for corrosion and / or loose terminal bolts.
JLM5151
09-18-05, 09:05 PM
I actually just got done doing that about a half hour ago and it seemed to fix the problem, I disconnected the + terminal for about 5 minutes and it, started right up after reconnecting it.
Might not hurt to get a wire brush and clean the connections just for the hell of it.
JLM5151
09-18-05, 09:37 PM
Don't think the skittles that my neice dropped down there helped too much heh.....:yup:
