automaticj5
09-14-05, 02:42 PM
When I first start my car, the navi screen reads the name kevin... Now I setup the car so when I push the memory button 1 it reads my name and moves to my position and so on... How do I make it the default and get rid of this kevin guy? Is there a way to set it up to where when I pull the key out or open the door the seat moves back(it does this now) but also when I start the car the seat moves to my position and so on?
TripleOught
09-14-05, 02:56 PM
i don't know how different the nav system is with the standard radio, but you should be able to set everything the way you want it, and i mean everything...then hold the memory button 1 until it chirps. that sets the 1 position to what you just did. then, you need to go into the personalized options and make sure the correct options are checked to allow it to remember you. for instance...
i set my 1 position, then made it remember me when i inserted my key. you can also make it remember you when you use the 1 keyless entry. it's a bit confusing in the beginning but check your manual and it will explain what all the options mean in the personalize section...
hopefully that helps...if not i'm sure you'll be back...like i said not sure how diff the nav is from mine...
In the menu, select personalize. That will allow you to change the name. Just go through your menu and you can select all of the other options as well. When in doubt, read the manual.
automaticj5
09-14-05, 03:11 PM
lol... ya thats an idea... read the manual... thanks guys, ill go check it out and get back if I have ?'s...
btw... its the bose 6 disc system... I think im in a lux sport as well... Idk any options it doesnt have...
