I have a 07 Escalade that will shut off after driving when my foot is taken of the gas, and it won't restart until it
has set for a couple of hours. It drives fine and runs fine as long as the gas pedal is being pressed. The amount of time driven or the distance driven does not matter for this issue to occur. There are no OBD codes stored, the
vehicle has a strong spark, and the fuel pressure is good. I had the vehicle towed to the dealership. The dealershipcompleted the same checks and found that BCM had lost communication. There were a lot of B codes and U codesstored. They pulled the ECM and BCM, cleaned and lubed the connectors because of fretting. They also replaced
the ignition switch because the power it supplied to some component was below the threshold. The vehicle worked fine for about 600 miles and now it has happened again. Warranty up! HELP
