View Full Version : 1973 deville reverse lights/ I need know how to change
ooblackrambo
09-13-05, 01:11 AM
:( I dont know how to change white reverse lights without taking the bumper off
its my first car and bought it from old lady(only 50,000 miles) and I am systematically changing everything.
ooblackrambo
09-13-05, 01:13 AM
I need help / its the only thing not working that and the analog clock
BluEyes
09-13-05, 07:28 PM
could you post a pic? I'm not familiar with the '73 rear bumper.
I know on my '70, you just unscrew the plastic lens, reach in and remove the bulb. The bulbs are the type that you push in and give a quarter turn to remove. Often on older cars the glass part will break free from the metal base though, and then you have to use needle-nose pliers to grab the base and remove it.
ooblackrambo
09-15-05, 04:12 AM
http://www.rrrclc.org/73_CPoz%20(4).jpg
white reverse lights on bumper right next to license plate
ooblackrambo
09-15-05, 04:15 AM
http://www.rrrclc.org/04Rallye%20(16).JPG
ooblackrambo
09-15-05, 04:43 AM
I know you can't change it from the trunk but if i look a bumper from under the car I can see the back of the light. The light on the back looks bolted on one side and welded on the other
BluEyes
09-16-05, 02:59 PM
got any closer pics?
You say you can see the back of the light - is it all metal on the back, or is there a whitish rubber/plastic fitting that the wires go into? If so, that probably comes out with a 1/4 twist.
Are you sure it is welded on one side and isn't a tab that fits into a slot? You could try removing that bolt and see what happens. Extensions and universal joints on the ratchet will probably be your friend.
ooblackrambo
09-18-05, 04:02 AM
http://www.geocities.com/ooblackrambo/73dvrrbm.jpg
http://www.geocities.com/ooblackrambo/73DRrBmpr.jpg
see of what you make of this ?
DaveSmed
09-18-05, 01:27 PM
Looks like the white part (socket assembly) twists out of the back of the light to facilitate bulb removal.
QQ plates? Where in Jersey are you located? I live right by Burlington.
Big_Blue
09-18-05, 03:24 PM
[/QUOTE] I live right by Burlington.[/QUOTE]
Not to change topic but I knew I seen that car before or just one that looks exactly like it when I was going to route 541 Burlington mall. It was sitting on the lawn next to some other car. I am stationed on Mcguire AFB NJ
