: Tricky
rnunez76
09-12-05, 07:15 PM
I have been having this problem recently on 98 deville. When I'm driving around quite a bit (i.e engine is warmed up), the engine will start to stutter. then after a bit more, the engine oil light starts blinking when I am at a light. If I start driving again, the light goes off. Now when I check the oil level everything is fine, not low on oil at all. What could be the causes of the stutter? where else should I look for an oil issue? :hmm:
Ranger
09-12-05, 07:49 PM
I do not know if the two are related or not, though I tend to think not, but the oil light is for oil pressure not oil level. Might just be a bad oil pressure switch. It is mounted on the oil filter adapter.
rnunez76
10-09-06, 12:54 AM
could this also be the cause of an oil leak?
Ranger
10-09-06, 11:52 AM
Possible, but not probable. You'll have to search around for the oil leak.
99Classillac
10-09-06, 06:29 PM
Hell yea it can cause a leak! I had a real bad leak comin out from the oil pressure switch. I had my 99 Deville for like 3 months when that happened. It was dripping all over my garage. Went to AutoZone. New switch was like less than $20. The dealer installed it for me for free(I bought 2 previous cars from him so it was good business).
Tonkin
10-09-06, 07:59 PM
Both my 96 Concours and 2002 DHS have had to replace the oil sender unit due to oil leaks. BIG ones!
Ranger
10-09-06, 08:17 PM
:hmm: Don't think I ever recall anyone saying that before. Guess I stand somewhat corrected, though I still don't think it is too common.
rnunez76
11-13-06, 07:14 PM
Ok I bought the oil sending unit, now where is located? Do I have to to remove the oil before changing it out? Thanks for your help!
Ranger
11-13-06, 07:48 PM
It's up on the oil filter adapter. You only need to remove the filter.
Murphyg
11-13-06, 07:59 PM
2 diff things said there.
Oil Pressure switch
Oil Sending Unit
Are they both the same thing ?
Ranger
11-13-06, 09:18 PM
It's a switch. It's either open or closed.
Murphyg
11-13-06, 09:44 PM
Oil Pressure switch
Oil Sending Unit
Is an Oil Pressure Switch the same thing as an Oil Sending Unit ?
Are they both one in the same component :confused:
Ranger
11-13-06, 09:56 PM
Different terminoligy, same component.
Murphyg
11-13-06, 09:58 PM
Th Yu
