DrDave
09-11-05, 11:41 PM
Why would there be two different part numbers for fuel injectors on an 82-83 eldo etc, vs. an 84-85 Eldo HT4100? They look the same... I *think* the connectors are same... why would they make them different numbers?
Do you think they might spray fuel at a different rate, or are they to comply with some emission standards or something?? I'm getting an '85 throttle body Unit, complete with TPS and injectors... for my '82 Eldorado.. and I just want to make sure the injectors are compatible with the '82 computer and eprom etc.
I know sometimes they change the part#s just because of connectors that you can swap... but these look very similar if not the same..
Maybe the '85 injectors just mount a little differently for the '85 throttle body, than in previous versions of the throttle body? ..so if I get the whole unit for my '82, it should be fine??
Does anyone know anything that might be of help for this issue??
Thanks for any help anyone can provide!!!!
