stickpony
09-10-05, 05:12 AM
I got a code E048, EGR System Fault trouble code on my '89 eldorado, after about 30 minutes of highway driving.. it stays on now..even after i clear the codes, it comes back.. how do i go about testing whether the EGR valve is bad or if the solenoid is bad? Im not familiar with using the caddy diagnostics to troubleshoot problems
91TexasSeville
09-10-05, 05:19 AM
It may only need cleaning and calibration. Use the search feature for "clean EGR". EGR system fault can be one of many little snakes, but normally it is a simple fix.
stickpony
09-10-05, 05:23 AM
i dont see how the egr system will clean itself.. that makes no sense.. am I amissing something here?
Clean the tubes inside throttle body and you will get rid of code but still may be not good for emission test.
stickpony
09-17-05, 01:44 AM
this did nothing to help the code.. it still sets itself.. anybody have a test procedure for the egr solenoid?
The easiest way to test the EGR solenoid to replace it with a new one. If it does not help, just return it. Replacing takes some 30 seconds. This subject was discussed a few months ago, search the archives for the procedure. You will need a vacuum gauge. You will most likely end up replacing the EGR valve.
globetrotter8888
01-05-06, 01:50 AM
I just looked up the Service Information Manual for E048 - EGR System Fault. The manual gives you a detail Flowchart Troubleshooting procedure to exactly pinpoint what is the cause - a faulty solenoid, EGR unit, leak or obstruction etc... and also a section on how to use the CCP and how the EGR control process work If you cannot find the manual in your library I will be happy to copy the flowchart and send you a copy.
Try buying a Service Information Manual from eBay (approx. $20 - $30) for your car, worth every penny that you will invest in the manual.
GT8888
