View Full Version : Where to Buy BCM for 89 DeVille
da_bills2
11-24-03, 04:27 PM
Hiya All -
Wonder if someone can give provide me with the follwoing information regarding the BCM in my 1989 Sedan DeVille:
- Where would the best place be to purchase one? I would rather not go to the dealer, but I have called most of the auto parts stores in my area and none seem to carry it. If someone purchased one, where did you get it from. I have also checked all of the junkyards here as well.. none have one from an '89... they just have ones from years '90, '91 and '92. I asked if they cross-referenced .. but they could not tell me.
- Where is the BCM located (I believe it is behind the glove box) and what does it look like? I found 4 metal boxes in this vicinity... one of which has to be the BCM... but I cannot tell just by visual examination
Box 1 - Long thin metal box (almost square) which has only one connector on it (with multiple wires). The plastic part of the connector says "RED" on it.
Box 2 - Long thin rectangular metal box with two connectors on it. Each connector has multiple wires attached to it. On the top of the box is what appears to be a hatch of some sort (looks like to alllow you to get at a memory module). I think this is it... but I am not sure. I also believe at least one of the connectors (if not both) were puple in color... but I could be mistaken on this.
Box 3 - small black box that looks like a relay box... has 4-5 separate connectors for individual wires. Attached with a clip to another plastic piece and is located very close to the vacuum hoses used for the air deflectors
Box 4 - Again lon thin metal rectangular box that has 6-8 connectors on it with each connector having multiple wires attached. This box is located on the Pass side wall... I believe this is the ECM module.
Any help would be greatly appreciated
TIA
rb31kct
01-08-04, 04:22 AM
Hiya TIA
I have the same question, where is the the BCM located and how to identify it??
I assume you´ve found out.
I appreciate an answer from anyone.
Thank you.
Ake
katdons3labs
01-14-04, 01:41 PM
Hiya All -
TIA
katdons3labs
01-14-04, 01:48 PM
check advance auto parts web site
they can get ahold of a BCM for you
They even show ya a picture of the BCM
For a 92 Deville they are in the neighborhood of 100.00 bucks
