: Just another another tire combination question
Silver Baron
09-08-05, 05:25 PM
255/40R18 Front
275/35R18 Rear
Did anybody try this combination on the stock rims yet?
Diameter wise it should be close enough.
But how about rubbing.
kimcheejeegae
09-08-05, 05:32 PM
255/40R18 Front
275/35R18 Rear
there are guys with 295s in the rear... 275 should be cake walk for the rears..
I'm running 255/45/18s at all four corners... the diameter with my set up is 1.3% larger than stock where as 255/40/18 are 2.4% smaller... I am sacrificing "slower" readings for a little more meat... I love it... btw.. no rubbing at all.
c4racer
09-08-05, 07:45 PM
also should fill out the wheelwells some. How does it handle - notice any difference?
Scott
Dreamin
09-08-05, 08:15 PM
Silver, that combo wont rub on stock rims.
But it may look funny... front's are almost 1/2" larger diameter than rears, which will be noticable.
Mat347
09-08-05, 08:25 PM
275-40s are much closer to the stock hight than 275-35s. tires.com has a size calculator that shows the differences vs stock size.
I have not seen it in person, but meats out back fits the Vs personality IMO and I will be going with a similar setup when I get new tires.
CVP33
09-08-05, 08:47 PM
I have 255/45/18's all around on my V right now. Only got to drive it for one day with that combo before she went in for the marathon of all dealer visits.
JOEYCTS-V
09-08-05, 11:04 PM
Has anyone run 265's yet? A friend of mine just got them for the front of his vette. I think they would work great all around. :stirpot:
talalhz
09-20-05, 06:51 PM
? Any one ?
urbanski
09-20-05, 08:31 PM
not 265, but 275 won't work up front.
http://www.cadillacforums.com/forums/showthread.php?t=49048&highlight=275
if after reading that you'd care to try 265s, feel free
evil 8
09-20-05, 09:38 PM
? Any one ?
Any one? Any one sporting evo avatars on the V sight?:tisk:
calicadi
09-20-05, 11:14 PM
Apparently you can go with 19 x 9 rims and 265/35/19 rubber all around (without suspension mods). Mallett offers this as one of their packages.
That fitment is probably what I'll go with. I'm still researching what competition rubber is available in that size. That availability may be the deciding factor over size. After that is resolved, I'll take careful measurements and determine if there's any room for lowering.
CTSVONFIRE
09-21-05, 12:23 PM
go to 1010tires.com and then go to tire size calculator it will tall u exactly how cloe they are.
CTSVONFIRE
09-21-05, 12:25 PM
Stock Tire - 255/40R18 >Search Tires Tire 1 - 275/35R18 >Search Tires
Section Width: 10.03 in 255 mm
Section Width: 10.82 in 275 mm
Rim Diameter: 18 in 457.2 mm
Rim Width Range: 8.5 - 9 in
Rim Width Range: 9 - 11 in
Overall Diameter: 26.03 in 661.16 mm
Overall Diameter: 25.57 in 649.47 mm
Sidewall Height: 4.01 in 101.85 mm
Sidewall Height: 3.78 in 96.012 mm
Radius: 13.01 in 330.45 mm
Radius: 12.78 in 324.61 mm
Circumference: 81.77 in 2076.9 mm
Circumference: 80.33 in 2040.3 mm
Revs per Mile: 799.0
Revs per Mile: 813.4
Actual Speed: 60 mph 100 km/h
Speedometer1: 61.0 mph 101. km/h
Speedometer Difference: - Speedometer Difference: 1.802% too fast
Diameter Difference: - Diameter Difference: 1.77%
CTSVONFIRE
09-21-05, 12:26 PM
I'm bored thought I would help out.
talalhz
09-21-05, 12:32 PM
Last I checked I own a 05 V !:thepan:
talalhz
09-21-05, 12:37 PM
Can some one confirm this for me (will they fit) , I'm geting the BFG KD's today:
255/40R 18 (F)
275/35R 18 (R)
AmesCTS-V
09-21-05, 12:50 PM
255/40R 18 (F)
275/35R 18 (R)
Dreamin already did answer you. They will fit and won't rub, but will look bad.
Silver Baron
09-21-05, 12:51 PM
talalhz: Can some one confirm this for me (will they fit) , I'm geting the BFG KD's today:
That was my original question at the beginning of the post :banghead:
evel 8: Any one? Any one sporting evo avatars on the V sight?
talalhz,
Evil 8 was refering to your avatar, which is not a V
Dreamin
09-21-05, 03:03 PM
255/40R 18 (F)
275/35R 18 (R)
Tal: As I said, these sizes will work, but it's a funky setup... I'm pretty sure Silver asked because the Falken 615's come in this size.
For another tire, you'd have more option, i.e. the "proven" 245/45 & 275/40.
FWIW, the BFG KD does not come in 255/40 and 275/35
