View Full Version : Code question.
jaugustavo
09-06-05, 07:46 PM
I was checking for codes the other day, and i got a P039 History code. Now I know that the code has something to do with Torque Converter Clutch (VCC) Engagement, but what exactly does this mean?
Thanks in advance.
adalla
09-06-05, 10:05 PM
To check VCC drive at some constant 50 mph and with your right foot on gas pedal touch the brake pedal with your left foot slightly to engage the brake switch. Watch RPM on DIC it should jump some 100-200 rpm. If it happens your VCC works properly.
jaugustavo
09-07-05, 04:33 AM
copy that. thanks. i'll check it out tomorrow.
jaugustavo
09-09-05, 05:45 PM
hey adalla, so i did what you said and my rpm's did jump a little. so what is the code being thrown for?
thanks.
adalla
09-09-05, 06:18 PM
So, there is nothing to worry about. Clear the code. How's your ATF level, condition?
jaugustavo
09-09-05, 07:29 PM
sweet. funny thing is i was planning on changing my ATF fluid anyways seeing how it has been awhile since its been changed. do i ave to change the filter as well?
thanks again. you have been most helpful adalla.
adalla
09-09-05, 08:38 PM
Yes, it is usually recommended to replace the filter and the pan gasket. Do not let anyone to flash the tranny, just drain, clean the pan, magnet and refill with Dexron III. I have recently bought a kit (filter, gasket) from NAPA. It was good.You do not need to change ATF if it does not have a burnt odor though.
