View Full Version : P013 and T063?
captainsavaho03
09-06-05, 11:53 AM
Could you guys check these codes and help me with the location.
I appreciate the help on the egr valve and fixed that problem.
Thanks.By the way she is a 95 Eldo!
Ranger
09-06-05, 04:42 PM
T063 .................................................. ........... Valve Relay Fault (ABS)
P013 (E013) .......................................... Right Oxygen Sensor Not Ready
Code definitions:
http://myweb.accessus.net/~090/dtcobd1.html
94greencaddysls
09-06-05, 04:54 PM
I had the PO13 error every once in awhile but its has ceased ever since the weather has warmed up...If your planning on changing that O2 sensor good luck getting to it on the back exhaust manifold behind the motor.
