john19990
09-05-05, 10:21 PM
The oil level sensor is next to oil filter on SLS 96. I have "Check Oil Level" message. I could not figure out how to unhook electrical connector on the sensor. Can anyone help me how to remove electrical connector. Should I use any screw driver to remove it?
john19990
09-06-05, 11:51 AM
Can anyone share how to remove electrical connector on the oil level sensor? I could not figure out - Thanks
94greencaddysls
09-06-05, 03:56 PM
its easy just pulls right out. you could use a screw driver to hold the tab up while you slide it off. Comes off like all the other electrical connectors on the car.
Turn the sensor body counter clock wise till you see a opening in the body use a small tool to gently pry the locking tab outward it will release the connector.sts96
