: 2000 STS Northstar Propane/LPG conversion - Europe
Jan Kraakman
05-04-14, 12:36 PM
Hello all,
Last year I've converted my STS to Propane/LPG. My goal was to install a liquid propane injection set due to my understanding that injecting the propane as a liquid in the intake like gasoline it would cool the mixture leading to an increased charging of the cylinders (no power loss) and eventually cooler burn temperatures (less temp. stress on valves etc.) compared to vapor injection. After searching the web I came to two brand options, Vialle and Icom. Since Vialle only allows their dealers to install their product and I, run my own shop for +32 years, wanted to install it myself the choice was easily made.:) Although the JTG2 system http://www.icomnorthamerica.com/jtg-ii-bi-fuel-3 (http://www.icomnorthamerica.com/jtg-ii-bi-fuel-3 is) is a fairly simple instal and adjust, I had to overcome some minor difficulties. I wanted the fill valve behind the gasoline fuel filler door but to gain acces from the inside of the trunk to the fuel filler housing I had to cut out / get thru the body inner metal.:wacky: The filler valve and hose are not Icom btw but temporally.
209953 209961
Jan Kraakman
05-04-14, 01:27 PM
I then started to install the 86 liter tank with intern fuel pump. But before I could I had to relocate the radio receiver that was mounted in the bracket behind the navigation unit.:stirpot:
210001 210017 210033 210041 210049 210057 210073
Submariner409
05-04-14, 02:19 PM
Nice work, Jon. Due to the extremely limited use of LPG in U.S. converted motor cars, I'll move your (ongoing ?) tutorial down to a permanent home in Cadillac Tech Tips.
Welcome to the Forums !!!!
Jan Kraakman
05-04-14, 04:03 PM
Thanks Submarine, :)
Here's the final tank install https://plus.google.com/photos/108430272854933847805/albums/6009656625402221937/6009660564506059826?pid=6009660564506059826&oid=108430272854933847805
I'll be posting more as soon as possible :yup:
Jan.
PontiacV8
05-04-14, 04:29 PM
...link doesn't "work"...( google+ account needed...!!) ;)
...btw....why didn't you use a toroidal tank (stako etc.) in the spare wheel area? (...to save some more space in the trunk)
Jan Kraakman
05-04-14, 04:51 PM
I've changed the sharing option in Picasa so it should work now, I've tried it on my wife's computer :stirpot:
The reason not using a toroidal tank was that the spare wheel space wasn't deep enough and the tank would be to small if I did :tisk::)
Jan.
