View Full Version : Trans Fluid Change Question
98 Caddy
09-02-05, 11:07 PM
After I drop the pan and pull the drain plug, what is my fluid fill proceedure? Do I put 5 quarts in and start it then add 6 more? Is the gasket reusable? Thanks guys. Great site!! By the way 98 Deville ;)
mcowden
09-03-05, 12:14 AM
Backflush the screens. They don't need to be changed. The gasket is reusable, just clean it off and also the sealing surface. Assuming you removed the hidden plug, once the pan is back and the bolts torqued in sequence, just dump in 11 quarts, check it, and add as necessary. You'll have to get it up to temperature to check it properly, and it will run and drive fine for long enough to heat it up. Check it hot after running through the gears and then add as necessary. Do NOT overfill it. If it's anything like mine, you'll need somewhere between 12 and 12.5 quarts of fresh Dexron-III fluid. They came with Texaco fluid from the factory if that makes any difference in your decision.
98 Caddy
09-03-05, 10:43 AM
Thanks for the response. Do you know what the torque value on the hidden drain plug is? So dump all 11 quarts in and then start. Wow that seems like a lot for the pan to hold without the pump pumping the fluid into the side cover.
turbojimmy
09-03-05, 12:54 PM
I didn't get anywhere near that much out of mine when I did the pan and the side cover drain. It's been a while, but I think 2 gallons (8 quarts) was even too much when I refilled it. I'd try to eyeball what came out and use your best judgement when refilling. It's a pain to get it back out if you put too much in (unless you have a siphon pump around).
Jim
Ranger
09-03-05, 03:50 PM
I replaced about a case (12 qts) when I did mine just a few months ago.
98 Caddy
09-03-05, 09:27 PM
Ranger, did you use the same refill technique? Did you dump in 11 quarts and then start it? I am not doubting you Mcowden just getting another opinion.
zonie77
09-03-05, 10:00 PM
Dumping it all in is the same as letting the car sit a few weeks, Not gonna hurt anything. As the trans seals wear it will let the fluid gradually leak down into the lower section when the car sits anyway.
I was gone 7 weeks and the car I left needed to run a minute to get the trans working. And it was a regular rear wheel drive. 4L60E Actually
Ranger
09-03-05, 10:02 PM
Oh boy, the memory is the second thing to go, you know. I think I put what the manual said in, then started it and found that I was overfull and had to suck out a half qt. or so. It definately to a case, give or take a qt.
mcowden
09-04-05, 12:06 AM
First I was gonna ask what was the first thing to go, then I thought better of it... Please don't tell us. :D
Anyway, my point is only that it should be perfectly fine to put in 5 or 6 quarts, run it a short bit, then dump in some more. As far as I can tell, it didn't hurt anything when I dumped in 11 to start, but I certainly don't know everything and would definitely be open to some further insight. I'm almost due for a second trans. fluid change anyway, so it's good to brush up on these things.
For clarity's sake, it only takes 11-12 qts. if you remove the "hidden" drain plug for the side cover. If you don't remove that plug, it will take probably 7-8 qts. but I haven't done it that way yet.
Let us know what you wind up doing and how it turns out for you.
zonie77
09-04-05, 12:30 AM
98Caddy,
I don't understand the problem. Would you take a chance of running the pump dry? I sure wouldn't.
Measure what you take out. Add 1 qt less and start it. Then add til it's full.
Ranger
09-04-05, 12:32 AM
To tell you the truth, I can't rememeber what the first thing to go is :histeric:. I do remember however that contrary to what has been said, in my case I got the vast majority of the fluid out of the pan. Very little out of the side cover ("hidden") drain. I know that is not supposed to be the case and is not what others have reported but thats was my expirience.
zonie77
09-04-05, 12:57 AM
Ranger,
Had it been sitting awhile? I don't mean 7 wks. Overnight or ? The seals keep the fluid up but they aren't oil tight. It will gradually leak down.
I had a torquefite that I didn't change all the seals (metal ones) because they looked good. Darn thing would drain down overnight. Every morning it took about 10 seconds to refill the convertor.
Ranger
09-04-05, 01:16 AM
Ah shit, here we go again with the memory questions. As well as I can recall, it sat overnight and I did it in the morning. I cannot drive it up on ramps due to the "bumper" height so if memory serves me correctly , I jacked it up and put it on jack stands. Don't think I started it in the morning.
98 Caddy
09-04-05, 02:28 AM
Zonie77, the reason I ask is because in a Ford rear wheel drive tranny (4R70w) you can drain the pan and the torque convertor via a drain plug in the convertor. You get about 15 quarts out doing this. If you put in any more than 9 or 10 quarts and start the truck it will blow the fluid out the vent on the top of the tranny. Just didn't want something similare to happen when doing the fluid change on the Caddie. Thanks
zonie77
09-04-05, 03:02 AM
Don't have any experience w 4r70w. Havn't had any other trans I've done act like that.
I measure how much I took out, by pouring into gallon jugs usually, then add a little less and start it up. I havn't had a problem. You can do it whatever way youl'd like.
98 Caddy
09-06-05, 11:41 PM
Mccowden, how excatly did you backflush the screens? Did you pull thewm and spray carb cleaner through them backwards? Thanks for the help.
Ranger
09-07-05, 12:39 AM
Thats what I did except I used kerosene in a parts cleaner but it was not needed as they were perfectly clean at 100K.
Kimura-sensei
09-07-05, 01:32 AM
I basically did the same when I changed my 99 deville tranny oil in spring this year. Drop the pan, clean the gasket, clean the square magnet on the pan, blew the screens (which were clean anyways), removed that hidden plug (it's hidden behind one of the screens and behind the wire bundle) and roughly 4-5qt came out of that sump well.
I dumped about 8-10 qts in there until I saw the ATF fluid. Turned my engine on for 5 secs, then turned it off for the tranny and pump to move the atf around. Filled up the rest until it's leveled. I think I used up 11.5 or 12.5, that much I know because I still have a half qt of ATF left in the bottle.
98 Caddy
09-07-05, 09:59 AM
Man I'm getting a little discouraged because my screens weren't that clean. There was a little metal caught in the screens.
mcowden
09-07-05, 10:17 AM
A little is OK and normal. As long as the screens aren't substantially obstructed with debris, they should be just fine. Just backflush them with carb cleaner or kerosene or whatever you have available that will reverse the flow and dislodge anything in the screens.
How was the magnet? What doesn't get caught by the screens gets caught by the filter. I don't think you have anything to worry about. A small amount of metal shavings and fine dust is normal. It looks scary when you look at the magnet, filter, and screen, but every transmission I've looked at has that to some extent and I really don't think there is anything to worry about.
