View Full Version : boring over displacement
Adumb
08-31-05, 11:28 AM
im going to need to bore my engine over. does anyone have a suggestion? .020 .030 .040 .060? any one better than another? my first instinct it .060 because its the biggest, haha. does anyone know what these different bores would increase the ci to? thanks
davesdeville
08-31-05, 12:11 PM
Usually I'd say bore the engine out to the smallest bore that you can get away with. If you can end up with a good cyl wall with .020 over, do .020 over. That way in 100k miles if you need to bore it again you can. If you're going for a big bore engine you can go with .120 over or so without any block fill and technically up to about .2 to .3 over with fill, but that's a bit over the top for your motor probably.
To figure out the displacement, use this equation, it will get you close enough:
CID = 8 (the number of cyls) x bore^2 (squared) x stroke x .7854
CID = 8 x 4.3^2 (stock bore) x 4.303 x .7854 = 500ci
CID = 8 x 4.32^2 (new bore .020 over) x 4.303 x .7854 = 504.5ci
turbojimmy
08-31-05, 12:42 PM
It may come down to what pistons are available. Smaller is actually better. It gives you more options in the future if you need to bore it again. Plus on some engines the bigger bore thins out the cylinder walls such that the combustion chamber heat begins to heat up the coolant a lot more.
When I had my GN rebuilt there was a shortage of .030 pistons so I had to go .040 over, which on the 3.8L block is the max. If I need to rebuild it again I may have to get another bock. Also, the car runs considerably hotter - I had to put a bigger radiator and bigger fans in it. I'm not sure if the Caddy blocks have this issue tho.
Jim
terrible one
09-01-05, 12:40 AM
davesdeville,
Can you work one for me? (boring the 500 .030 over). I just don't understand the equation and can't get it to come out as anything near 500. Boy do I feel stupid!:cookoo:
Adumb
09-01-05, 11:34 AM
yeah,i agree with terrible one. i am not terrific at math. what is "^"? thanks.
turbojimmy
09-01-05, 12:51 PM
The "^" is "to the power of" or in this case 'squared'.
Jim
terrible one
09-01-05, 01:22 PM
I just want to know how many cubic inches I will end up with:rolleyes:
turbojimmy
09-01-05, 02:57 PM
.020 = 505
.030 = 507
.040 = 509
.060 = 514
terrible one
09-01-05, 05:45 PM
Thanks
Adumb
09-01-05, 10:33 PM
so, if i bored .020 over i would have a 476, right?
i think i did the equation right.
terrible one
09-02-05, 12:03 AM
sounds correct
Adumb
09-02-05, 01:27 AM
i did all the math so i figured id share so you guys dont have to. here it goes.
472
.020 = 476
.030 = 478.2
.040 = 480.4
.060 = 484.9
and im fairly sure my math is right. thanks for the equation dave.
davesdeville
09-02-05, 07:39 AM
Thank Google.
And come on guys, I got a D in Algebra I, and a D- (actually an F, but I went to class 4 extra days and did extra work for a D-) in Algebra II, but I still got that equation.
Adumb
09-02-05, 09:19 AM
well, i havent taken a math class in 2 1/2 years so everything i learned is basically gone, haha
terrible one
09-02-05, 01:10 PM
I suck at math. That's okay though because nice people one the forums can work out my displacement equations. :)
turbojimmy
09-02-05, 01:41 PM
I'm no math whiz either, but I am a geek. I popped the formula into Excel and referenced a cell with the overbore value in it (.020, .030, .040, .060). I just changed the value in that cell and the output changed. I'm sure there's a web page somewhere that has a similar tool - but you have to know the input values (standard bore, overbore and stroke).
Jim
JTraik
09-03-05, 12:45 AM
Jim
Or you can just store the equation in your TI :2thumbs:
terrible one
09-03-05, 12:50 AM
JTraik how is your project coming?
