: Bushing part #s and Torque specs
jdodman
08-29-05, 07:20 PM
Can someone post the part numbers for the new bushings that correct (or improve) the wheel hop, along with the torque specs ??
I am setting up an appointment for the V and want to see if they will take care of this.
Is there a recall ?? Dealer bulletin ??
Anything I can referance beside this BB, as ammo ?
Thanks,
Joe
Luna.
08-29-05, 08:06 PM
There is a bulletin.
I'm going fast, but I think this is it:
http://www.cadillacfaq.com/faq/tsb/data/tsb/05-04-114-001A.pdf
jdodman
08-30-05, 07:02 PM
Thanks Luna...That was exactly what I was looking for.
revcoman
08-30-05, 11:43 PM
I didn't see any torque specs in that bulletin?
Anyone in 'the know'?
ctsvett
08-31-05, 12:09 AM
here is the entire rear suspension torque specs from the manual:
Adjustment Link to Frame Retaining Nut
175 Nm
129 lb ft
Adjustment Link to Knuckle Retaining Bolt
175 Nm
129 lb ft
Brake Pipe Bracket Retaining Nuts
10 Nm
89 lb in
Differential to Frame Mounting Bolts
175 Nm
129 lb ft
Frame to Body Bolts Front
265 Nm
195 lb ft
Frame to Body Bolts Rear
191 Nm
141 lb ft
Half Shaft to Knuckle Retaining Nut
160 Nm
118 lb ft
Lower Control Arm to Frame Retaining Nut
150 Nm
111 lb ft
Lower Control Arm to Knuckle Bolts
175 Nm
129 lb ft
Parking Brake Cable Bracket Bolts
60 Nm
44 lb ft
Shock Absorber to Body Retaining Nuts
25 Nm
18 lb ft
Shock Absorber to Knuckle Retaining bolt
150 Nm
111 lb ft
Stabilizer Shaft Bracket Bolts
60 Nm
44 lb ft
Stabilizer Shaft Link Nuts
50 Nm
37 lb ft
Trailing Link to Frame Retaining Nut
90 Nm
66 lb ft
Trailing Link to Knuckle Retaining Bolt
175 Nm
129 lb ft
Upper Control Arm Ball Stud to Knuckle Retaining Nut
First Pass
20 Nm
15 lb ft
Second Pass
+ 210
Upper Control Arm to Frame Retaining Bolt
175 Nm
129 lb ft
Wheel Bearing/Hub Assembly Retaining Bolts
125 Nm
92 lb ft
Rear Frame Insulator Anchor Bolts to Body-Front
265 Nm
195 lb ft
Rear Frame Insulator Anchor Bolts to Body-Rear
191 Nm
141 lb ft
