View Full Version : hardwiring V1
c4racer
08-29-05, 01:34 AM
Speaking of V1's, I need to wire mine up in my new V. Any tips on where to pull power from in the sunroof / int. lighting console on the roof?
Scott
c4racer
08-29-05, 01:34 AM
looking for switched ignition power so it will turn on with the key.
Scott
ctsvett
08-29-05, 02:08 AM
http://www.cadillacfaq.com/faq/answers/v1install.html
This will go off with RAP power (about 10-20 mins after the car shuts off) and on when you hit the remote button or open the door...
Never had a dead battery with this method... (knock on wood)
Reed
RocketV
08-29-05, 11:16 AM
Reed
It also takes only about 5 minutes to complete, including running the wire to the unit.
c4racer
08-29-05, 11:21 AM
perfect - just the info I needed. I will do it one evening this week. thanks guys.. http://www.cadillacforums.com/forums/images/icons/icon14.gif
Scott
JohnnyU
08-30-05, 12:55 AM
The hardest part I found was running the phone wire under the plastic piece to pull it through to the wiring harness in the sunroof area. I ended up shoving some coat hanger wire through, and making a loop to pull the wire in. Secondly, my crimp clamps were crap, and I ended up splicing the wires - so mine has a nice solder job - either way, the wiring for the V1 worked fine.
