: trans. leak
08-28-05, 06:05 PM
the transmission fluid is just dissapearing out of the transmission with no apparent leaks?. after a day of driving , its below the lowest level of what it should be at when cool. I tried bars leak, that didnt help. someone said that the fluid was burning up? but how could this be?...the radiator is new so the cooling of it should be fine. The only thing that I could possibly think of is that one of the lines from the radiator to the trans. is clogged. what could it be clogged with though, is that a possibility? i cant tell any difference between the fluid being low and full when driving.:annoyed:
08-29-05, 01:21 AM
ok, I think I found the leak, theres fluid drippng now from the bottom seal in the rear of the engine undernieth the car. is it hard to fix a leak?
