: Error code P035
medhat
08-25-05, 07:25 AM
I bay a nortstar V8 model 93 the error code is P035
what it means
any help please
Eldyfig
08-25-05, 11:16 AM
PCM reference low signal voltage Out of Range
Never crossed this one before. What is your battery voltage? Is the code current or history?
Welcome to the forum.
medhat
08-27-05, 04:34 AM
Thank you
my battay voltage 13.4v
medhat
08-27-05, 05:39 AM
Thank you
medhat
08-27-05, 05:42 AM
The battery voltage 13.4 V and the code is current
another thing the RPM keep change from 1500 to 500 and some time the engin stop
please advise
madoc1
01-25-07, 05:33 PM
i have the same prob. am sure my isc is bad but do not know what the heck 035 means. does any? thx jim
Cad tech
01-26-07, 05:37 PM
CIRCUIT DESCRIPTION
The diagnostic test monitors the REF LO voltage (CKT 453) input to the Powertrain Control Module (PCM) and sets the code if the voltage difference between REF LO and PCM power ground is greater than certain preset values.
The PCM internally adds 2.5 volts to the REF LO signal. If the voltage is above 3.98 volts or below 1.04 volts it is considered out of range and Code P035 is set.
TEST CONDITION
Code P016 not set.
FAILURE CONDITIONS
Voltage difference between PCM ground and Ignition Control Module REF LO 1.48 volts or greater for 1 second. OR
Voltage difference between PCM ground and Ignition Control Module REF LO 1.46 volts or less for 1 second.
ACTION TAKEN
None
NOTES ON FAULT TREE
If the value of PD09 is 1.1 volt or less, this means that the PCM ground voltage is floating high causing P035 to set.
Checking for a short to voltage on CKT 453.
Voltage measured at ignition control module connector "C4" terminal "F" should be less than 0.1 volt. If the voltage is higher, then the module must have a bad ground causing the module to ground through the REF LO input to the PCM.
NOTES ON INTERMITTENTS
This code may set due to an improperly installed PCM. This may cause the PCM to not be electrically isolated from the body ground.
01-31-07, 08:21 AM
Here's the diagnostic chart and wiring pin out...
acarew
02-23-13, 01:47 PM
I posted the same problem in a different thread. Ckt 453 is the red/blk wire from the blue pcm terminal to the f termial on icm correct? With the blue clip unplugged and key on I am reading voltage through that wire, any idea where/how I might hunt down the cause?
