Uncle Junie
08-23-05, 05:57 PM
Thanx for letting me be part of the CADDY FAMILY. Once you drive a "LAC" you wont go back. I'm the proud owner of a 92 Sedan Deville when I turn on the ac it runs for a while then the fuse blows can anyone help?
| View Full Version : I need a/c Uncle Junie 08-23-05, 05:57 PM Thanx for letting me be part of the CADDY FAMILY. Once you drive a "LAC" you wont go back. I'm the proud owner of a 92 Sedan Deville when I turn on the ac it runs for a while then the fuse blows can anyone help? CADDYBLACK99 08-29-05, 10:36 PM Welcme Uncle Junie! Thanks for joing the "family". I will move your post to the Deville section for better responses. Good luck. :welcome: Paul Ranger 08-29-05, 10:54 PM Might be a clutch going bad. Uncle Junie 08-31-05, 08:39 AM Thanx ranger but I upgraded to a 2000 Deville with the northstar. Anything I should know about this model year? Ranger 08-31-05, 11:30 PM The only thing that comes to mind about the 2000 is that they are known to just die. Crankshaft sensors were a problem in that year so if they have not been replaced and it should die on you, that is the first thing I would suspect. | |
