zbgsaa
08-22-05, 11:49 PM
So i got my 472 back up and running. CHanged out the starter wires...ground alternator wires is messed up but i can start the car and take the keys out and will still run
| View Full Version : Car starts but wont cut off ahhh zbgsaa 08-22-05, 11:49 PM So i got my 472 back up and running. CHanged out the starter wires...ground alternator wires is messed up but i can start the car and take the keys out and will still run Colt D 08-23-05, 01:51 AM Do you have HEI ignition? Check the power going to the dist. If it is hot with the ignition key in the off position, that's the prob. It should be a source that it only hot with the key in the on/run position. There is a thread in this forum that describes installing the HEI ignition that you may find helpful. If you have stock points ignition, check the power going to the + on the coil. If that is hot all the time, same thing. | |
