: 94 caddy
08-20-05, 04:35 PM
:bomb: 94 deville left key on after changing and checking turn signal light on pass side back. after that had to jump car battery was dead. had to change fuse in trunck to ipc after that every thing works except ipc help cant see how fast i'm going ect.
08-20-05, 05:22 PM
doesnt sound good ...check every fuse in the car and get back to me ..lets make sure nothing else is down that may inhibit IPC operation
08-20-05, 05:23 PM
also ensure the knob for the dimmer is turned to the right to the point just before the dome lights illuminate ...
push (and hold) off and warmer , tell me what happens , among other things this will give us a segmet check of the ipc
08-20-05, 05:35 PM
checked every fuse with meter just to be safe. Off and warmer lights up the service soon lite and gos off when auto is pushed.pannel is blank so no codes flash. its like a blown fuse not sure where else to look even checked maxie fuses in engin compartment and all in trunk. originally ipc fuse was blown in trunk. all other operations working.air-heater turn signals ect.
08-20-05, 05:54 PM
sounds like the ipc took a hard lick ....seems like we have a vendor here that deals in IPC restorations/repairs
since you did the off and warmer test that tells me we cant blame the dimmer for the issue
jumping is very hazzardous to todays cars
08-20-05, 06:11 PM
Is that pretty much remove ipc and send it for repairs?
08-20-05, 06:13 PM
thats what im thinking
08-20-05, 06:15 PM
i would send him an email and see what he can do ....i havent used him yet myself but he looks like a good alternative to finding a new one
08-20-05, 06:51 PM
08-20-05, 06:55 PM
Would junk yard unit be ok or repaired the best way to go
08-20-05, 06:59 PM
if you can test a junkyard unit to ensure it works then go for it ....but thats the problem .....most cars there have dead batterys or no batterys ...or the ipc has been removed , and jundgeing by the fact you had to jump it i dont thinky ou have a jump start box ....
if the yard offers a warranty , or can allow you to test go for it , if they do boath for you , DO IT...and know you found a good yard
08-20-05, 07:13 PM
first time on here thanks for all the help
08-20-05, 09:01 PM
no problem ,glad to have you here ,tell us about your car
08-20-05, 10:16 PM
been a really great car. but recently had tran rebuilt transfer went out now this but quality and ride are worth the extra i guess. 158000 miles so i should expect repairs are forthcoming.
08-20-05, 10:34 PM
YUP ....it happens , expect to replace everything the belt touches ...and i do mean everything
trannys go bad , pretty typical ,as do sway bar end links and other things ...
then there is me .....i bought mine for 4900 and now i think im at 6300 invested , for a total of $11,200
for that i could have gotten this :
and looked like this:
08-21-05, 01:06 AM
Welcome to the forums.
08-21-05, 03:12 PM
Is there a power source that serves just icp other than the fuse in the trunk?
08-21-05, 03:24 PM
i got the manual out to check , according to it there are 3 fuses that feed the IPC , 2 of them are in the trunk , "a-5" (powered at all times)and "b-5"(powered in run) boath of which are 10 amp , then there is another 10 amp under the hood in position "a-3" that only has power in run
08-21-05, 04:07 PM
Sorry to hear your having problems. Stoney's a good guy and will help you out a lot. BTW Welcome to the forums. Good luck on the repair and post some pics when you get a chance.
08-21-05, 08:42 PM
Ok thanks I checked all of them guess its time to take it out. Any tips on how to remove it?
07-04-06, 07:12 PM
Hi Everyone in Caddy Land,
As like most I have a queston. My 94 Sedan Deville trunk lid will not close automatically. I checked the fuse and it was okay. Also, my antenna won't go up or down. I unplugged the circuit so it wouldn't burn out. The beauty, she's a gettin' worn out eh!
07-14-06, 08:52 AM
Welcome to the forum!
Thanks for signing up with us.
07-18-06, 07:23 AM
Welcome. Sorry about your problem. I speak from personal experience that if anyone can help you with your Caddy, the people here can. Good luck!
