View Full Version : Radio,cd,tape Problems
BOODER
11-17-03, 11:45 PM
New Owner Of 90 Allante With A Few Problems. The Worst Is The Driver Info Center And I'm Looking For Clues. When I Bought The Car The Radio Would Not Turn Off,change Station,or Get Volume...and, The Cd/tape Did Not Work Either. All Three Radio Related Fuses Are Good. Three Of Us Spent A Day (with Tech 1) On The Radio.. We Did Get It Working (with Components In Our Hands)--all Functions "great". Didn't Spend A Lot Of Time On Cd/tape. Then We Installed The Info Center,checked,and Sure Enough- The Mighty Fine Radio Was Stuck On One Station,would Not Turn Off,change Station,or Volume. Next I Can Think Of Is Check For A Bad Connection Or Wire. Note: The Previous Owner Mentioned Some Rain With Top Down*** What Do You Think? And What's With These Cd's (understanding A Lot Don't Work)? If It Got Wet,can It Be Repaired? Or What Are The Most Common Problems? I Recently Joined The Forum And See A Lot Of Good Info. Not Real Bright Here (mi.) So Please Try To Keep It In "old Slow English". Will Appreciate All Of Your Commments Even If You Jest---don
carnut
11-18-03, 01:21 AM
Try Disconnecting The Battery For A Few Min. Sometimes Rebooting The Computer Will Solve The Radio Problem. Also Suggest Getting On The Allante Appreciation Group Forum And List This Problem In Their Public Area. Type In Allante.us Should Bring It Up. Hope This Helps. I Own An '88. Great Car!
Allante North *
11-20-03, 07:32 AM
CD players are prone to go bad. Ricklo in San Diego found a shop close by that has Allante CD players in stock and his report was good. Dayton Speedometer will rebuild the units for a fee now(used to be free), Try Carnut's suggestion and see if that helps. My CD player works when it wants too which lately is not at all.
Good Luck
rickko
11-21-03, 07:24 PM
CD players are prone to go bad. Rickko in San Diego found a shop close by that has Allante CD players in stock and his report was good.
Good Luck
Here is a list of all the places I've had good luck with including LaJolla Audio Repair for the CD. Some of these items may only apply to '93 Allante's.
DONNELLY: Rear view mirror replacement. 616-786.7171. Lisa McKellips
FAXON: Owner's Manual and other manuals. 800-458.2734
D.HUSSY: Factory Service Manual www.allantesource.com
TRIPLE A ENTERPRISES: Factory window sticker. 800-924.8347
LA JOLLA AUDIO REPAIR: Refurbished CD players. 858-373.0596. Ask for Cleeve.
SUPERCHIPS: Hi performance chip. 407-547.0130
Any store that stocks K&N filters: K&N air filter for '93 = Part #33-2086
LEATHERMAGIC: Leather recoloring kit. 800-232.4092
HYDRO-E-LECTRIC: Cockpit only car cover. 941-639.0437
TOM ROHNER: Allante Embroidered Floor mats. 858-674.5777
RADIO SHACK: Battery for keyfob light. Part #23-1504. On the battery itself it says, PX625A.
BMW Parts Dept.: Tiny bulb for trunk keyfob. Part # 51-21-1-935-001
KRAGEN: Wiper blade inserts. Driver's side- TRICO 43-200. Passenger side- All Season 21640
..rickko..
BOODER
11-21-03, 11:01 PM
This Is Really Some Great Info And I Appreciate All Of You Taking The Time To Comment.. Please Keep It Coming, It's All New To Me.. Soon, I Will Be Reporting Results From Your Suggestions. Thanks From Freshman Member--don
carnut
12-17-03, 11:30 PM
Never heard what it took to fix the radio? did disconnecting the battery help?
BOODER
12-18-03, 10:06 PM
**************************I HAVE NOT DIS-CONNECTED BATTERY YET BECAUSE I HEAR THE D.I.C GOES NUTS,, SO I AM WAITING NOW FOR FRIEND TO COME OVER HERE AND STRAIGHTEN THINGS OUT WHEN I RE-CONNECT. WILL POST ASAP. DON****************************
