: Surge tank
Dadillac
08-14-05, 12:49 PM
As stated in an earlier post, I changed my coolant this morning. I have a small rant. It may just be that I am anal retentive. Why would GM, design a surge tank, that is going to house orange coolant, with black, and "orange" plastic? Before the coolant change, I assumed that the plastic was just showing the coolant color through it. After removing, and cleaning the tank, and noticing that the plastic was orange tinted, I couldn't believe my eyes. I am no rocket scientist, or car designer. But, even I can figure out, that the semi-transparent white plastic, would be a much better choice. Rant over.
Don
cguthrie
08-17-05, 04:57 PM
Thanks for the reminder. Coolant OK. Oil level 1 quart low.
I hear your pain!
I believe the dark surge tank container was designed to match the dark tab on the end of the oil stick! (yes, I've heard it was originally a lighter color and has just cooked & changed color over time)
Maybe I'm just getting old because I have to pull out the flashlights just to check my fluid levels these days!
CG
99 STS 116K
Dadillac
08-17-05, 05:07 PM
I hear your pain!
CG
99 STS 116K
Is this true? Was the surge tank, when new, much lighter in color? Or are you just busting my chops? :thumbsup: It would seem difficult to believe, that a three year old car, would have the plastic surge tank, discolor so quickly. It definitely looks to have been made this color. But, I could be mistaken (that would be the first time ;) ).
Don
cguthrie
08-17-05, 07:18 PM
Sorry Don,
I was reffering to the tab on the end of the dip stick, which I believe was supposed to be yellow. Mine's well, the color of oil after a couple thousand miles!
I believe the surge tank was always blackish, but I would have preferred it to be clear similar as the brake fluid reservoir. You bring up an excellent point.
Didn't mean to bust your chops,
CG
Ranger
08-17-05, 08:14 PM
I don't know what you guys are talking about. My surge tank is opaque black :mad:.
I hear ya on the dipstick though. I have to read it in the sunlight. I have often thought about molding a new one or machining one out of steel and brazing it to the cable.
JimD
08-17-05, 08:50 PM
Regarding the oil dipstick:
Put some faith in the crankcase oil level sensor (and the DIC message "CHECK OIL LEVEL") which makes the oil dipstick redundant.
I have learned to ignore the CHECK OIL LEVEL message on a cold start. If I see that message on a hot start, I will consider adding one guart of oil.
Over 142,000 miles on a '98 and going strong. YMMV.
