Just found these...
ACS Splitter for Cadillac ATS
If ever a car were designed to be stylistically augmented by one of our stunning, fully prepped and primed Splitters then it is the Cadillac-ATS. Not only will it add an extra visual dimension to the car’s sleek build, but it will add aerodynamics and guile at high speed to a vehicle that already handles like a dream.
With the option of an extraordinary black satin finish, this ACS Splitter is must have addition to any ATS.
The ACS Cadillac Splitter carries the following features as standard:
Improved frontal airflow management
Fuel optimizing air-restricting mechanism achieved via central opening
Manufactured in an OEM-validated RTM composite material
Complete undercarriage pan for protection and rigidity
Use of OEM mounting points for simple assembly
Will not lower the front ride height of the car
ACS Side Rockers for Cadillac-ATS
Where style, performance and fun align in perfect synergy.
The Cadillac brand has always represented luxury and with the ATS Cadillac have realised that luxury should not come at the expense of performance. Here at ACS we agree and adding our aerodynamic and stylish Side Rockers is a fine start!
Fully prepped and primed our ACS Side Rockers are smoothly moulded using an RTM composite process that banishes rough edges on either side.
The installation process takes only 30 minutes per side, using the mechanical fastener kit supplied and avoiding the use of messy adhesives or even double-sided tape.
The Cadillac-ATS Side Rockers carry the following features as standard:
Enhances your car’s aerodynamics at high speeds
Will not lower the ride height of the vehicle
Smooth finish to both sides that looks and feels good, and facilitates easy cleaning
Mounted to the original OEM rocker panel
Installation kit including (Passenger/ Driver Side Rocker Panels, 18 Scrivets, 16 U-nuts & Bolts, Easy Instructions).
Compatible with several other splitters on the market
Optional satin black paint finish
Source: http://www.acscomposite.com/2014/02/acs-composite-ats-splitter-rocker/
