View Full Version : Saving pictures from the Gallery
Eric91z
08-02-05, 02:53 PM
OK, I like to visit the Gallery to check out pictures and thought, at some point, that I was able to right click and save the pictures once I had them pulled up. Now when I try that, for the file name when it tries to save it says watermark.php and will not save the actual picture.
I have also tried to right click on the picture and open in a new window and still get the same thing when trying to save a picture. Has something changed that we can not save the pictures? Is there a work around or am I doing something completely wrong?
Any input appreciated.
Thanks.
Kev
08-02-05, 04:12 PM
Thanks.Eric,
If you save it to your hard drive as *.php with WinXP you can open the file with any web browser and you can also open it with MS Paint or Paint. In Paint you can edit or save as any format that Paint is capable of saving as.
It's a little convoluted but as work around non the less.
Hope this helps you out.
Eric91z
08-02-05, 05:58 PM
I will try that. Thanks.
Edit: I tried that and it worked as a work around. Thanks.
