View Full Version : Heater valve control - 89 Fltwd
Caddyguy TCM
02-22-03, 10:30 AM
...Can anyone tell me what to look for on climate
control sytem....blower control works as should, but vacuum
controlled water valve won't shut off hot water to heater....I
suspect vacuum problems, but don't know where to start....
89 Fltwd...........Good buy......runs great......body good, fixer-upper.
Katshot
02-22-03, 11:52 AM
If you MANUALLY connect and disconnect the vacuum, can you control the water? Or is it just a bad valve? If it's just a vacuum issue, first make sure you have the RIGHT VALVE in the car. Some were made normally open, and some were made normally closed. They are interchangable on the car. I've seen it before where someone has the wrong valve and it seems like the heater won't work, or won't shut off.
If the valve is right and it's just a vacuum control issue, check the programmer behind the dash, then the control head. I've usually found vacuum leaks, disconnected hoses, improperly connected hoses...... But sometimes it ends up being the programmer or head.
Caddyguy TCM
02-24-03, 10:27 PM
Kevin........Thank you for the info........Have a mechanic helping
me....The Climate Control will not read out any OBD codes at
all, but Indicators light.........buttons work........and digital
temps raise and lower apparently ok........
He says I have to replace the Climate control first.......Any ideas
on this part of it.........\
Thanks.......Paul, Caddyguy
Dead Sled
02-25-03, 12:10 AM
thats knid of an expensive part to just be throwing in there to see if it fixed it. Id suggest trying to get more in depth to the problem before throwwing parts at it. I know when I had no heat I thought the thermostat was stuck open, but was the radiator cap
Caddyguy TCM
02-25-03, 12:45 PM
Ok...........Can anyone tell me if the climate control from
an 84 deville would directly interchange with the one from
this 89 Fleetwood............Have sent the 84 to my backyard
graveyard for parts.....Thanks............Caddyguy
jadcock
02-25-03, 02:50 PM
I'd definitely check the heater control valve on the engine itself. An '89 Fleetwood should have an Oldsmobile 307 V8, with the heater control valve on the rear of the passenger side cylinder head. Check for vacuum here when the heater is engaged. If you need to remove it, be careful -- the threads are about 1" if I recall correctly.
Katshot
02-27-03, 04:27 PM
If you ever want to know what parts interchange with what, check with the local salvage yard, they have a book that shows the interchanges.
Mad'lac
02-27-03, 08:17 PM
I want that book!!!!! I seen my parts guy look up countless things for me in that book. Can we the public get that book?
Caddyguy TCM
11-03-03, 10:21 AM
UPDATE: 11/03/03 - PROBLEM TURNED OUT TO BE A VACUUM
HOSE PINCHED UNDER A BRACKET FOR AC .......GOT VACUUM,
GOT VALVE WORKING PROPERLY........BUT STILL HAVE INTER-
MITTENT COOPERATION FROM CRUISE CONTROL.....
Tailfin
01-09-04, 04:37 AM
The cruise control is probably unrelated to the heater valve. All I can think of in that regard is there's a thing under the hood that pulls on the throttle when the cruise is engaged. That or the throttle itself might simply need lubricating. Other than that, it could be an issue with the computer. For your sake, I hope it isn't the latter :tongue2: .
