deeman
07-23-05, 01:13 PM
Just finnished installing the 500 in my 4x4 truck.The fuel pump has two ports coming from it.Since i do not have a return lines to my dual tanks,can I block the other outlet off or would there be problems?
| View Full Version : fuel pump outlets deeman 07-23-05, 01:13 PM Just finnished installing the 500 in my 4x4 truck.The fuel pump has two ports coming from it.Since i do not have a return lines to my dual tanks,can I block the other outlet off or would there be problems? The Ape Man 07-24-05, 11:48 AM You can block the return off. It's there to lower fuel temperature at the carbonator inlet. If you have problems with hot restarts then consider plumbing a return line to the tank. deeman 07-24-05, 12:54 PM Thanks Ape Man ,I just blocked it off and it seems to work fine so far.A real problem that I have is that I run each tank seperately so having a return line would be a PITA. | |
